Getting started with MAX
in MAX by AMX
Dear all,
I am getting started with the MAX products, specifically the MMS-04S.
I need to accomplish a complete automation with moderos.
I found in the website the MAX4Plus Show for TPDesign4. Ok, but and the Netlinx programming?
How do I do that, working with the MMS-04S?
I had read an old answer in this forum which says something about to install the " UI module in your NetLinx master", what that means?
Someone can help me?
Thank you veru much
Thank you veru much
Also make sure in line 1429 where you define the UI module, that you use your correct variable for the touchpanel that you defined under DEFINE_DEVICES | (*REAL TP's*) . Besides that, cut and paste the appropriate pages into your touchpanel file and you should be good to go.
Hope it's not too basic of an answer, but just wanted to cover the "install the 'UI module in your NetLinx master', what that means?" part of the question.
--John
