Home AMXForums Archive Threads AMX Applications and Solutions VisualArchitect
Where is code?
Okay, I know I need glass's but where do I obtain the code to enter at the start of the install of VA 1.2 ? I have 1.0 installed.
  • It is on the CD case, but I am not sure if you can upgrade 1.0 or if you needed 1.1? You should have been automatically sent a 1.1 disk when it came out. The fun part is seeing the difference on the CD case because it wasn't marked so well...
    Curt
  • travtrav Posts: 188
    Yeah,
    We've been getting an ever increasing number of calls from people who have 1.0 and have tried to webupdate to 1.2. You need to get a copy of 1.1 as it has a serial number and requires you to authenticate with AMX when you install it. Much the same as they are doing with Cafe Duet.
    It's free, so just send off a purchase order and away you go :)
    -Trav
