Jupiter Fusion 980 - Rx Issues
                    I wrote a program for a video wall system that is using the Jupiter Fusion 980. I've used a Jupiter a few times before and have never had the problems I'm having now.
The first problem is that I can send strings to the Jupiter and it works fine, but I don't get any responses back from the Jupiter. I have verified the baud rate is correct, I'm sending the 'RXON' command, and I have used multiple cables which I have verified were correct. Using the same cable and hyperterminal, I hooked my laptop directly to the Jupiter and I get responses back from the Jupiter. I also connected a cable tuner to the same port on the AMX master and was able to send and receive strings. So, I'm kind of at a loss as to what the problem may be there.
The second problem is that after a period of time the Jupiter will stop responding to commands, and since I'm not receiving responses back from the Jupiter, it's making it a bit hard to figure out what the problem is. If I reboot the Jupiter, it starts responding to commands again. I think the problem might be within the Jupiter itself (Galileo Connect and the ControlPoint Server).
Any help is greatly appreciated!
- Chip
As for handshaking, I am also sending the 'HSOFF' command.
DEFINE DEVICE
dvJUP = 0:2:0
dvNI = 0:3:0
DEFINE START
GET_IP_ADDRESS(0:0:0, MyIPAddr)
IP_SERVER_OPEN(dvJUP.Port,25456,1)
IP_CLIENT_OPEN(dvNI.Port,MyIPAddr.IPAddress,25456,1)
I am using a Linksys wireless router w/ IP: 192.168.50.1
The Master is: 192.168.50.254
The Jupiter is: 192.168.50.114
I was able to ping the master from the Jupiter.
Also, I set up Diagnostics to monitor strings on 0:2:0 and 0:3:0 and I'm not seeing any strings being sent.
DEFINE_DEVICE dvNI = 0:2:0 DEFINE_VARIABLE VOLATILE CHAR sIPAddress[] = {'192.168.50.114'} // Jupiter IP // Connect code ... I wouldn't put this in DEFINE_START. Attach it to an event or create a // Timeline that will attempt to re-connect as long as the connection does not exist. IP_CLIENT_OPEN(dvNI.Port, sIPAddress, 25456, 1)(Sorry about the lack of formatting - I keep forgetting how to get it in one of those nifty little code boxes.)
dvJUPITER1 = 0:2:0 //Jupiter 1 - TCP/IP connection
DEFINE_START
IP_CLIENT_OPEN(dvJUPITER1.PORT,'192.168.1.10',25456,1)
DATA_EVENT[dvJUPITER1] // TCP/IP VERSION
ONLINE:
nJUPITER1Online = 1;
WAIT 20
SEND_STRING dvJUPITER1,"'Admin',13,10"
WAIT 20
SEND_STRING dvJUPITER1,"13,10"
OFFLINE:
nJUPITER1Online = 0;
// Attempt to re-establish communications
IF (nJUPITER1KeepOpen)
WAIT 300
ONERROR:
SWITCH(DATA.NUMBER)
// No need to re-open socket in response to following two errors.
CASE 9: // Socket closed in response to IP_CLIENT_CLOSE
CASE 17: // String was sent to a closed socket
DEFAULT: // All other errors. May want to re-try connection
WAIT 300
