New TPI/4 Firmware Available
New firmware for NXP-TPI/4 has been posted to amx.com under the file name 2275_01C_V2_46_64.KIT. It can be found by following this path: amx.com | Dealers | Tech Center | Firmware Files | NXP-TPI/4, TP4-VID, TP4-RGB.
This replaces the previous version, 2275_01C_V2_43_57.kit.
Release Notes:
--Supports TakeNote application
--Fixed memory leak when playing audio files
--Added support for latest version of RealVNC
--Added popup features: Slide Left, Slide To Left, and Slide From Left.
--Enhanced dynamic image support for HTTP servers not supporting HTTP standard correctly.
--Changed default SSID for wireless connections to "AMX" to support new AMX WAP.
--Fixed several page flip problems in setup pages.
--Corrected issue of panel not waking properly after display timeout.
--Fixed lockup problem where panels would lock up after 24.8 days.
--Fixed resync issue with master where master would come up quickly via soft reboot and panel would not reset channel states.
--Added support for Eyegonomics touch monitor
--Added support for automatically detecting USB keyboard/mouse
Release Notes:
We've created some dynamicaly dropdown-menus for a big project with many Boxes of TPI4.
We realised the dropdown-menus with a lot of buttons (between 30-100) wich are dynamicly updated from Netlinx (Visible / Unvisible and a dynamic Button-Text wich is updated from a structure in Netlinx)
Now we have to update the firmware of the TPI4 to be compatible with the new TPDesign 2.3.
Now our the dropdownmenus runs very slowly (during the update from Netlinx (1-4 Seconds) the Mousecursor is freezed!)
The old Firmware that we used was the TPI4_v2_13_47.kit
Is there a way to become the update-speed that we have before?
Thank you for your support...
