same projector, different results
so today I was testing various notebook computers by hooking up the VGA monitor out to a 50' VGA cable, the other end which was connected to a Sim2 HT305. Of the 5 I tested, 2 worked fine, and the other 3 it couldn't find a signal. A guy from Dell tech support suggested different laptops might output more power to the VGA out. He said 50' was pushing it without an amp.
anyone else experience this or get to the bottom of it?
Joe
To complicate things, apparently some of these laptops worked (over a shorter VGA cord) to a cheap NEC projector. Unfortunately I was not around to supervise all tests.
With that knowledge, this post is a little vague, but I am thirsty for Laptop+VGA+projector knowledge. Particularly with length of cable since given all the facts, this seems like the most likely issue.
You are really stressing the poor VGA output and I'd hate to think of what the Sync pulses look like ~ I would strongly suggest an Extron interface so that you can adjust the peaking & level to compensate for the cable losses.
When i hook it up to a plasma or LCD most of the times it works.
Also a Dell for me, an Inspiron 510m, but i can't be arsed to get my mobo replaced
