ISDN Router
                                  in AMX Hardware
                    Hi All,
I want to connected to a Netlinx system onsite from my office. The site has ISDN for its codec so i got a Cisco 801 ISDN router to go on to our own network onsite.
Has anyone every try to configer one of these. I have been dialing in to it and it connects but i cant see the netlinx at that end.The Cisco software is asking for a IP address for the ISDN IP network then a IP address for the local IP network which is the one on the Netlinx network.
Can anyone help me?
Can anyone help me?
Are you set up for port forwarding or are you tunneling in by VPN? You're connecting the the router so I assume it either has a static public IP or you have a dynamic DNS account set up for it or do you just know its current assigned dynamic public IP.
I am dialing to the router from a ISDN card in my laptop and then trying to telnet to it or from NS2.
There is no setup for port forwarding i have tryed VPN as well.
I generally do the same as Dave but the opposite. I keep my LAN IP in the default 192.168.1.1 (Linksys) range but subnetted which is irrelevant and my clients IPs at something like 192.168.10.1. This works good for me but if you're not setting up the clients network Dave's method works best. Actually Dave's approach is probably better regardless for a host of reasons.
