Home AMX Technical Discussion
Send program via script
I once read in a manual that there is a way to package a program into a script or batch file so I can give it to anyone to install by simply double clicking an icon.
I can't find that manual.
Does anyone know where I should be looking.
    Are you talking about ?Export Workspace Files To Go? under the Project menu in Netlinx Studio 2?
  • champchamp Posts: 261
    I've found it right under my nose.
    Using FTCon, a dos implementation of File Transfer 2.
    I thought it was an older program.
    You literally make a batch file and give it to the installer or client with the program.
    It's a little complicated but using File Transfer with a File transfer list can be too much for some people.
    With FileTransfer it's also possible just to give the To-Go file (.AXW) away. If the .AXW is configured correctly (IP settings, device mapping, etc.), all the stuff can be downloaded by 1 or 2 simple clicks.
