Channels?
adys
Hi all
I have a modlue for DENON DVD3910 (from AMX site)
I was trying to sent buttons ON/OFF with no success, then after I remarked this code everything is working. I asked about this code before and didn't undestand what its doing...
DEFINE_PROGRAM
// DEVICE ONLINE
[dvTP, nCHAN_BTN[DEVICE_ONLINE_BTN]] = [vdvDEVICE, DEVICE_COMMUNICATING]
// DATA INITAILIZED
[dvTP, nCHAN_BTN[DATA_INITIALZIED_BTN]] = [vdvDEVICE, DATA_INITIALIZED]
// POWER FEEDBACK
[dvTP, nCHAN_BTN[POWER_ON_BTN]] = [vdvDEVICE, POWER_FB] // DISCRETE POWER ON
[dvTP, nCHAN_BTN[POWER_OFF_BTN]] = ![vdvDEVICE, POWER_FB] // DISCRETE POWER OFF
// DISC TRANSPORT FEEDBACK
[dvTP,nCHAN_BTN[STOP_BTN]] = [vdvDEVICE,STOP_FB]
[dvTP,nCHAN_BTN[PLAY_BTN]] = [vdvDEVICE,PLAY_FB]
[dvTP,nCHAN_BTN[PAUSE_BTN]] = [vdvDEVICE,PAUSE_FB]
[dvTP,nCHAN_BTN[SLOW_FWD_BTN]] = [vdvDEVICE,SLOW_FWD_FB]
[dvTP,nCHAN_BTN[SLOW_REV_BTN]] = [vdvDEVICE,SLOW_REV_FB]
[dvTP,nCHAN_BTN[SCAN_FWD_BTN]] = [vdvDEVICE,SFWD_FB]
[dvTP,nCHAN_BTN[SCAN_REV_BTN]] = [vdvDEVICE,SREV_FB]
Also I found out the the STOP_FB and all the rest of the XXX_FB are constants that defined in the 'SNAPI.axi' file.
can someone please explain me what this code is doing?
thanks
Ady.
DEFINE_PROGRAM
// DEVICE ONLINE
// DATA INITAILIZED
// POWER FEEDBACK
thanks
Ady.
Feedback is all this is, this code has no effect on whether or not your DVD will turn on or off or do anything else.
thanks but this is a fact
I checked it again, when unremarking this code, the ON OFF state on a PLAY_BTN buttons don't work and its the only change from working to non working code...
*****Maybe I didn't explain my self so good, its the ON OFF state of the PLAY_BTN that its not working, not the command. the command is ok.
looks like this code create a channel maaping?
Like I said, the statements in DEFINE_PROGRAM control feedback. I thought you were saying that the DVD player didn't work (note, I'm defining 'work' as the device doing what it is supposed to do when given appropriate commands) with the DEFINE_PROGRAM section gone, which would make no sense. But the code turns your touchpanel channel nCHAN_BTN[POWER_ON_BTN] on or off depending on the value of the channel POWER_FB on your virtual device. So in that sense yes it does create a channel mapping.
I see, thanks.
What is this 'SNAPI.axi' include file? its in the AMX Share directory.
this constant is coming from this file.
It's just an include file of constants used by modules that adhere to the AMX module standards so that values that are typical across a broad range of equipment can use these global constants with out dupications.
