Home AMX Technical Discussion
Diagnostics message unclear....
Line 82 :: ICSPTCPRx31: Ignoring msg from foreign device (same DPS) (IP=0xC0A80134) Cmd=2 DSys=1 DDev=0 TCP Socket=31 IP=192.168.1.52 Index=1 - 11:34:03
Line 83 :: Routing Loop detected. Killing route to system 1. - 11:34:03
Line 84 :: ICSPTCPRx30: Ignoring msg from foreign device (same DPS) (IP=0xC0A80133) Cmd=2 DSys=1 DDev=0 TCP Socket=30 IP=192.168.1.51 Index=0 - 11:34:06
Line 85 :: Routing Loop detected. Killing route to system 1. - 11:34:07
Line 86 :: ICSPTCPRx31: Ignoring msg from foreign device (same DPS) (IP=0xC0A80134) Cmd=2 DSys=1 DDev=0 TCP Socket=31 IP=192.168.1.52 Index=1 - 11:34:07
Line 87 :: Routing Loop detected. Killing route to system 1. - 11:34:07
the above is copied out of my diagnostics window. these messages seem to appear now and again, and im unsure why they do. they don't seem to adversely affect the system, but i'd like to know if there is a problem....
the AMX system is an NI-3100 as master and running all code (diagnostics was taken from this processor), with two NI-900's connected via IP which contain no code, and are just used as extra control ports.
NI-3100: IP = 192.168.1.50, Device 1, System 1
NI-900 1: IP = 192.168.1.51, Device 1, System 2
NI-900 2: IP = 192.168.1.52, Device 1, System 3
The URL listing table is only present in the NI-3100 and only contains the IP addresses of the two NI-900s.
Can anyone shed any light?
mark
  • The "Routing Loop detected" makes me assume that your masters all still have System Number 1.
    Do you have rebooted the masters after setting the system numbers?
    You can check that for example by terminal/telnet with the SHOW DEVICE command:
    >show device
    Local devices for system #2 (This System)
    Device (ID)Model                 (ID)Mfg                    FWID  Version
    00000  (00285)NI Master          (00001)AMX Corp.           00296 v3.21.343
           (PID=0:OID=0) Serial=0,0,0,0,0,0,0,0,0,0,0,0,
           Physical Address=IP 172.16.100.12:1319 (00:60:9f:90:bc:39)
             (00285)vxWorks Image    (00001)                    00296 v3.21.343
             (PID=0:OID=1) Serial=N/A
             (00285)BootROM          (00001)                    00298 v3.00.316
             (PID=0:OID=2) Serial=N/A
             (00256)AXLink I/F uContr(00001)                    00270 v2.12.140
             (PID=0:OID=3) Serial=0000000000000000
    05001  (00286)NI-3000            (00001)AMX Corp.           00299 v1.12.140
           (PID=0:OID=0) Serial='N/A',0,0,0,0,0,0,0,0,0,
           Physical Address=Internal Connection
    33001  (65534)Virtual            (00001)AMX Corp.           00296 v3.21.343
           Physical Address=None
    So my system here has system number #2.
  • markbsuremarkbsure Posts: 44
    thanks for the reply marc.
    I am sure all the processors are set to different system numbers. The system numbers were set when i first installed the equipment, and all processors have been rebooted many times during the programming of the system! The code running in the master NI-3100 references the two NI-900 ports with their respective system numbers (2 and 3) and works fine.
    when i next get back on site i will double check this via telnet, but I'm pretty sure the system numbers are correct.
    It looks to me like the kind of thing you might get if one of the other masters also has a URL entry back to the first one.
  • ondrovicondrovic Posts: 217
    Dont mean to hijack this post but I also am having this problem
    show system
    Local devices for system #1 (This System)
    00000  (00299)NI Master          (00001)AMX Corp.           00380 v3.21.343
           (PID=0:OID=0) Serial='210515x4860218',0,0
           Physical Address=IP 10.1.1.200:1319 (00:60:9f:91:d4:11)
             (00299)vxWorks Image    (00001)                    00378 v3.21.343/0
             (00299)BootROM          (00001)                    00379 v3.21.343
    00128  (00188)COLOR LCD TOUCH PAN(00001)AMX Corp.           32786 v5.12b
           (PID=0:OID=0) Serial=0000000000000000
           Physical Address=Axlink
    00129  (00188)COLOR LCD TOUCH PAN(00001)AMX Corp.           32786 v5.12b
    00130  (00188)COLOR LCD TOUCH PAN(00001)AMX Corp.           32786 v5.12b
    00131  (00188)COLOR LCD TOUCH PAN(00001)AMX Corp.           32786 v5.12b
    00132  (00188)COLOR LCD TOUCH PAN(00001)AMX Corp.           32786 v5.12b
    00133  (00188)COLOR LCD TOUCH PAN(00001)AMX Corp.           32786 v5.12b
    00134  (00188)COLOR LCD TOUCH PAN(00001)AMX Corp.           32786 v5.12b
    00135  (00188)COLOR LCD TOUCH PAN(00001)AMX Corp.           32786 v5.12b
    00150  (00224)Mio Modero         (00001)AMX Corp.           00000 v-.--
           (PID=0:OID=0) Serial=Unknown
    00151  (00224)Mio Modero         (00001)AMX Corp.           00000 v-.--
    00152  (00224)Mio Modero         (00001)AMX Corp.           00000 v-.--
    00153  (00224)Mio Modero         (00001)AMX Corp.           00000 v-.--
    00154  (00224)Mio Modero         (00001)AMX Corp.           00000 v-.--
    00156  (00224)Mio Modero         (00001)AMX Corp.           00000 v-.--
    00157  (00224)Mio Modero         (00001)AMX Corp.           00000 v-.--
    05001  (00286)NI-3100            (00001)AMX Corp.           00383 v1.12.140
    10001  (00288)MVP 7500           (00001)AMX Corp.           00400 v2.72.2
           (PID=0:OID=0) Serial='596501X4760187',0,0
           Physical Address=IP 10.1.1.209
             (00288)Kernel           (00001)                    00401 2.4.20-2
             (00288)Root File System (00001)                    00402 v2.72.2
             (PID=0:OID=3) Serial=N/A
             (00288)Bootrom          (00001)                    00403 v2.72.2
             (PID=0:OID=4) Serial=N/A
             (00288)Sensor           (00001)                    00404 v2.72
             (PID=0:OID=5) Serial=N/A
             (00288)Opt File System  (00001)                    00405 v2.72.2
             (PID=0:OID=6) Serial=N/A
             (00288)Battery Base     (00001)                    00308 2.04
             (PID=0:OID=7) Serial=N/A
    10002  (00288)MVP 7500           (00001)AMX Corp.           00400 v2.72.2
           (PID=0:OID=0) Serial='596501X0670339',0,0
           Physical Address=IP 10.1.1.210
    10005  (00304)DMS                (00001)AMX Corp.           00353 v1.00.120
           (PID=0:OID=0) Serial=240801WHX4660139
           Physical Address=IP 10.1.1.208
    32001  (00262)NSX Application    (00001)AMX Corp.           00281 2.50
           Physical Address=IP 10.1.1.103
    33002  (65534)Virtual            (00001)AMX Corp.           00380 v3.21.343
    33003  (65534)Virtual            (00001)AMX Corp.           00380 v3.21.343
    33004  (65534)Virtual            (00001)AMX Corp.           00380 v3.21.343
    33005  (65534)Virtual            (00001)AMX Corp.           00380 v3.21.343
    33006  (65534)Virtual            (00001)AMX Corp.           00380 v3.21.343
    33015  (65534)Virtual            (00001)AMX Corp.           00380 v3.21.343
    34000  (65534)Virtual            (00001)AMX Corp.           00380 v3.21.343
    34001  (65534)Virtual            (00001)AMX Corp.           00380 v3.21.343
    00000  (00298)NI Master          (00001)AMX Corp.           00341 v3.21.343
           (PID=0:OID=0) Serial='210503x4760160',0,0
           Physical Address=IP 10.1.1.201:1319 (00:60:9f:91:d1:cc)
             (00298)vxWorks Image    (00001)                    00339 v3.21.343
             (00298)BootROM          (00001)                    00340 v3.21.343
    05002  (00286)NI-700             (00001)AMX Corp.           00346 v1.12.140
    Local devices for system #3
    00000  (00298)NI Master          (00001)AMX Corp.           00341 v3.12.335
           (PID=0:OID=0) Serial='210503x3460928',0,0
           Physical Address=IP 10.1.1.202:1319 (00:60:9f:91:a5:70)
             (00298)vxWorks Image    (00001)                    00257 v3.12.335
             (00298)BootROM          (00001)                    00340 v3.00.316
    05003  (00286)NI-700             (00001)AMX Corp.           00346 v1.12.140
    Local devices for system #4
           (PID=0:OID=0) Serial='210503x3460740',0,0
           Physical Address=IP 10.1.1.203:1319 (00:60:9f:91:a6:0f)
    05004  (00286)NI-700             (00001)AMX Corp.           00346 v1.12.140
    Local devices for system #5
           (PID=0:OID=0) Serial='210503x4760148',0,0
           Physical Address=IP 10.1.1.204:1319 (00:60:9f:91:d1:87)
    05005  (00286)NI-700             (00001)AMX Corp.           00346 v1.12.140
    Local devices for system #6
    00000  (00312)NI Master          (00001)AMX Corp.           00341 v3.21.343
           (PID=0:OID=0) Serial='210509x0460277',0,0
           Physical Address=IP 10.1.1.205:1319 (00:60:9f:91:5d:d6)
             (00312)vxWorks Image    (00001)                    00381 v3.21.343
             (00312)BootROM          (00001)                    00340 v3.21.343
    05006  (00286)NI-900             (00001)AMX Corp.           00382 v1.10.127
    Local devices for system #7
           (PID=0:OID=0) Serial='210509x1260094',0,0
           Physical Address=IP 10.1.1.206:1319 (00:60:9f:91:6e:47)
             (00256)AXLink I/F uContr(00001)                    00270 v2.01.126
    05007  (00286)NI-900             (00001)AMX Corp.           00382 v1.10.127
    I have the WHC control master which is system 1 pointing to the others:
    Here is my url list
    SYSTEM 1
    1.   10.1.1.201
    2.   10.1.1.202
    3.   10.1.1.203
    4.   10.1.1.204
    5.   10.1.1.205
    6.   10.1.1.206
    getting this error message
    Line 99 :: ICSPTCPRx41: Ignoring msg from foreign device (same DPS) (IP=0x0A0101CE) Cmd=2 DSys=1 DDev=0 TCP Socket=41 IP=10.1.1.206 Index=9 - 12:39:58
    Line 100 :: Routing Loop detected. Killing route to system 1. - 12:39:58
    Any ideas???
    The error messages look like what DHawthorn said...
    You may have a URL setup from the main master (system 1) to the 2 secondary masters (systems 2,3) and then systems 2,3 back to the main master.
    You only need to do an URL from the 2 secondary masters to the main one. That sets up the two-way communication from all three masters.
    To state it another way, you do not need to enter in any URL link from the main system master (system 1)
  • AlexArtistAlexArtist Posts: 51
    markbsure wrote: »
    mark
    This error is most likely NOT becuase of your master to master setup. I once had this problem aswell. What's causing the error is you have an event (most likely a level event) that gets sent to one master. Triggers and event there. Then info gets sent back to the original master, triggers and event there. The orignal master then triggers an event back to the remote master... etc... Bascially, an Infinite loop starts. Level Events are usually the main cause of this. Comment Out some level events on one of your masters until you find the event causing the inifinite loop. Then figure out how to prevent it.
