Pioneer PDP 5000ex - 232 control?
or any control other than IR.....
has anyone tried to control this plasma? it has a 9pin d-sub which is entitled "Service" and the standard Pioneer command protocol seems to have no effect....
... and i cant seem to monitor anything coming out of this port at most baud rates...
.... and Pioneer UK tech support weren't any help.....
if no-one else can shed any light i will have to resign myself to using the discrete IR commands.....
mark
mark
... though he did think that 232 would be added in a firmware release in a few months.....
.... i'm not holding my breath though
haven't been able to test it out yet, but it looks hopeful!
goes to show - dont trust the manufacturer's tech support team......
markb
The key point is that the RS232 port will not work if SR+ is activated. I had to disable it
in the service menu for the PDP-R06E. From the document mark posted it seems to be available in the user menu on the 5000ex. Once this is done RS232 control works fine. I assume it is the same accross the entire pioneer plasma range. I found feedback to be quite limited on the R06E so ended up using IR anyway but 232 does work.
Ps. I happen to work above a pioneer service centre so i called them and asked an engineer i know about the Rs232 control. At first I got the standard "that port is only used for service" line. Later on he realised it was me calling so he came up and spent half an hour showing me how to do it. He even gave me some software to help test all the various commands.
Oh, so it would seem it's policy to lie to the customer about the use of that port. They just don't want to have to deal with the support end of it. Since there are probably commands you can send that will mess the set up, I don't blame them, but I'm still put off that they feel it necessary to lie instead of limiting the data to certified dealers like anyone else would do.
With the PDP-5000EX/PRO-FHD1, the serial port is commonly used by the RS-232C and SR+ connectors. Although the setting upon shipment is RS-232C, it can be changed to SR+, using the Home menu. If SR+ is selected, to use the RS-232C commands during servicing to control the unit the setting must be returned to RS-232C.
How to switch between SR+ and RS-232C:
There are two ways to switch: (1) by using the remote control unit during Standby mode, and (2) by using the Home menu.
(1) Switching by using the remote control unit during Standby mode
• From SR+ to RS-232C
With the unit in normal Standby mode, press a key other than the Standby key. Then within 10 seconds, hold the
Volume + (or -) key pressed for 3 to 10 seconds.
Then hold the 2-screen key pressed for 3 to 10 seconds. Then within 3 seconds, press the Enter key.
The Standby LED flashes twice.
Then the setting is switched to RS-232C, and the baud rate becomes 9600 bps.
• From RS-232C to SR+
Then hold the 2-screen key pressed for 3 to 10 seconds. Then within 3 seconds, press the HOME MENU key.
Then the setting is switched to SR+.
(2) Switching by using the Home menu
Press the HOME MENU key. Move the cursor to Initial Setting, using the Up or Down key, then press the Enter key.
Move the cursor to SR+, by the Up or Down key. Move the cursor to "Off," using the Left or Right key.
Press the HOME MENU key to exit the Home menu.
Press the HOME MENU key. Move the cursor to Initial Setting, by using the Up or Down key, and press the Enter key.
Move the cursor to SR+, by using the Up or Down key. Move the cursor to "On," by using the Left or Right key.
Press the HOME MENU key to exit from the Home menu.
Some people prefer to work with this device using a timeline, though I'd rather work with it based on the feedback I'm getting. If feedback fails though, you need a safety net (such as buffering / queuing the commands) so that if you don't recieve feedback for whatever reason (gremlins eating the recieve wire, etc.) it will still switch.
Hope this helps!
I feel the same way. I've spoke with Pioneer several times and it's always the same BS that it's used for service and that's all. Sharp is the same way. We almost need a group of guys that just hack these pieces, and post all the information, or an insider to relay all the information.
I haven't done more than power, inputs and aspect stuff. if you have a question just ask. maybe i could even post the pdf here....
В режиме стандбай:
кратковременно нажать SPLIT
зажать на 5 секунд VOL+
зажать на 5 секунд SPLIT
кратковременно нажать ENTER
индикатор стандбай 2 раза мигнет.
Это переключит плазму в RS-232 на скорости 9600.
In Standby mode:
quick press SPLIT then
hold 5 seconds VOL+ then
hold 5 seconds SPLIT then
quick press ENTER
(SPLIT = 2-screen key)
We are installed 3 plazma display with it.
dvPLAS1 = 5001:3:0 //PLASMA 1 ON SERIAL PORT 3 Pioneer Model PDP 505CMX Straight Thru 2, 3, 5, 8 F to F
//Plasmas MUST have an ID before serial commands will be accepted. To assign an ID, initiate Integrator mode as follows:
//Turn on Plasma
//On the remote, press and hold "Display" for up to 5 seconds, until Integrator screen displays
//Press "Menu"
//Use arrow keys under "Option" tab to navigate to Baud Rate and ID Number Set
//For setting baud rate, "Set" cycles thru settings
//For ID Number Set, Press "Set" then use arrow keys to select digits
//Press "Set" to save
//Press "Menu" to exit
//Command Structure:
//SEND_STRING dvPLASMA, "$02,'**INPOS1',$03"
//** = Plasma Number
Here are the commands that Pioneer begrudgingly gave me:
COMMAND PARAMETER FUNCTION
POF POWER OFF
PON POWER ON
VOL xxx VOLxxx LEVEL VALUE (EXAMPLE: VOL 015)
VOL UPx (x= 1-9) INCREASE VALUE 1 -9
VOL UP0 INCREASE 10 VALUE
VOL UPF SET TO MAX VALUE
VOL DWx (x= 1-9) DECREASE VALUE 1 -9
VOL DW0 DECREASE 10 VALUE
VOL DWF SET TO MIN VALUE
AMT S00 AUDIO MUTE OFF
AMT S01 AUDIO MUTE ON
INP S01 INPUT 1
INP S02 INPUT 2
INP S03 INPUT 3
INP S04 INPUT 4
INP S05 INPUT 5
INP S06 INPUT 6
INP S07 INPUT 7
AVS S01 AV SELECTION: STANDARD
AVS S02 AV SELECTION: DYNAMIC
AVS S03 AV SELECTION: MOVIE
AVS S04 AV SELECTION: GAME
AVS S06 AV SELECTION: PURE
AVS S07 AV SELECTION: USER
AVS S08 AV SELECTION: ISF-DAY (AFTER CALIBRATION)
AVS S09 AV SELECTION: ISF-NIGHT (AFTER CALIBRATION)
SZM S00 SCREEN SIZE: DOT BY DOT/PARTIAL (PC ONLY)
SZM S01 SCREEN SIZE: 4:3
SZM S02 SCREEN SIZE: FULL/FULL 1080i
SZM S03 SCREEN SIZE: ZOOM
SZM S05 SCREEN SIZE: WIDE
MST S00 SINGLE WINDOW DISPLAY
MST S01 MULTI WINDOW: 2 SCREEN(MAIN SCREEN SIZE: NORMAL)
MST S08 SWAP (REPLACE SUB-SCREEN FOR PIP)
OSD S00 OSD DISPLAY OFF
OSD S01 OSD DISPLAY ON
SRS S00 SRS OFF
SRS S01 SRS ON
TBS S00 TRUBASS OFF
TBS S01 TRUBASS ON
FCS S00 FOCUS OFF
FCS S01 FOCUS ON
INA xxx ANTENNA A ANALOG xxx CHANNEL(EXAMPLE: CHANNEL 35 = INA035)
INA xxxxxx xxx ANTENNA A DIGITAL xxxxxx xxx CHANNEL(EXAMPLE: CHANNEL 5.001 = INA000005001)
INB xxx ANTENNA B ANALOG xxx CHANNEL(EXAMPLE: CHANNEL 35 = INB035)
INB xxxxxx xxx ANTENNA B DIGITAL xxxxxx xxx CHANNEL(EXAMPLE: CHANNEL 5.001 = INB000005001)
INA or INB FWD PRESET CHANNEL 1 STEP FORWARD (EXAMPLE: INBFWD)
INA or INB REV PRESET CHANNEL 1 STEP BACK (EXAMPLE: INAREV)
