Problem with web control
I have a NI-3100 that lost a connection when I login from internet.
I have a router tha NAT my intranet,I ask if is it a problem with a router or a NAT if my system lost a web control connection
    If there was once a connection, it's not likely that the NAT or router setup was bad in the first place. However, I have seen far too many times all manner of network wonkiness that can be repaired by restarting the router and any local switches, or restarting the NetLinx. Not all network devices play well with each other if there is any kind of glitch. I would restart the NetLinx first, then restart all the network devices, starting with the router. If that does it, put a UPS on all these things to help prevent it happening again.
  • problem with web control
    Thanks for your help...I now try
