URC's MX-3000 and AMX
Could this remote be used as a user interface for an AMX system?
This is strictly one-way IR, no feedback. It seems to me, using the URC product to control an AMX is a waste of the product's capabilities. If the project is simple enough that this suffices as an interface, perhaps you don't need a controller at all.
Thanks, but I was refering to use it with RF as a user interface for another room like a bedroom that will have some sources from the main rack to control them. Still won't have any feedback but it could be a solution for small rooms.
Isn't the RF unit for that just a receiver with IR outputs? I've done what you are talking about, but mostly I just parallel the non-AMX remote with the AMX and let them both control it. It's rare that feedback is an issue with simple systems anyway.
we had a little trouble using the NI-700s IR recievers. It seems the AMX codes you get of remote central cause problems in the NI-700 if you are simultaneously recieving IR in and 'TO-ing' IR out from the IR port of the NI-700.
I programmed in a few delays and that helped solve the problem.
Overall, I was very pleased with the results.
ejm
I've done that too with a RTI remote using the AMX wireless codes. It works like a champ. Some people on this board helped me through it.
