maths in netlinx studio
has anyone got a clue about mathematics in netlinx studio?
i often try to calc things like -sMyTemp*0.292+32.667 and i get errors unless i
try (-sMyTemp*0.292)+(32.667) which maybe makes sense if one knows the rules.
i don't know them...
i remember having problems especially with minus and comma before, i never got what i wanted
I'll admit that I'm really old-school when it comes to this kind of thing and I still do the old-fashioned method of multiplying my whole equation by (in your case) 1000 to get rid of the decimal place, doing the math, and then dividing the whole thing by 1000 to get it back down.
Another thing to try is go ahead and make the constants 0.292 and 32.667 into variables and see if that helps.
So for example:
define_variable
FLOAT sMyTemp
FLOAT some_variable_1=0.292
FLOAT some_variable_2=32.667
And then the equation will look like
result = (sMyTemp * some_variable_1) + some_variable_2
Now, if you're referring to the convention of the equation, the rule is the same for most programming. What's in the parens gets done first.
So, the order from the above equation will be
step 1
sMyTemp * 0.292
then the result of the above will have
32.667 added to it.
Hope that helps.
EJM
sTemp * 2 + 2
it will work... but sTemp * 2.2 + 2.2 needs brackets around the floats.
btw:
sTemp * (2.2) + (2.2) will also work
Eric lists a few good policies. Here are some of mine:
(1) Use parentheses everywhere to enforce the precedence you want even if right now you know what the compiler's precdence rules are, because the next person who looks at your code might not remember the rules - and that person might be you in a couple of years.
(2) Explicitly type partial products by holding them in a local variable so you know exactly what you are getting at each step, and you then don't have to guess how the compiler will handle it. Here's a quickly thrown together not-very-good example, uncompiled and untested:
(3) Avoid floating point partial products entirely using Eric's "multiply by 1000 first" approach.
