DATA.TEXT still limited to 255 characters ?
vincen
Hi,
As told in subject, DATA.TEXT is still limited to 255 characters or is there a way to get that limit up ? as I prefer to use data.text in events than old fashions CREATE_BUFFER
Vince
Vince
From the NetLinx.axi file:
But like noted above, in most cases it is best to do a CREATE_BUFFER, because you never know if the data received is a complete dataset.
If is a string from a Device (i.e. Keypad data from a panel, virtual device, etc.) you can work directly with DATA.TEXT, because this data comes on "system level",so the string is always complete.
Yep but then it's yet better to use old fashion CREATE_BUFFER because all the more DATA.TEXT is a char so impossible to receive extended characters in it
Vince
Thanks for the detail but why do we have only 255 characters avalaible in programmation ? It looks strange that restriction
Yep I think I'm going to continue in the old fashion way
Not really as it's for IP communications and I receive a string of nearly 15k of characters so I'll use BUFFER and CREATE_BUFFER as we did in old time in Axcess
Thanks for all
Vince
Well I consider it old fashion as it means you need to use DEFINE_PROGRAM loop which is not in my idea best way to program in NetLinx. All programs I do in NetLinx don't have any DEFINE_PROGRAM neither DEFINE_START section as it was good only in Axcess
Vince
I think you are mistaken. DEFINE_START is the only place some things can be done (CREATE_LEVEL and CREATE_BUFFER being only two examples). In most cases you can do without DEFINE_PROGRAM, but I would hardly qualify "good programs" as never using it. You are limiting yourself to only some of the tools in your toolbox with that kind of view. Just the fact they existed in Axcess doesn't make them obsolete. Besides, you can still use CREATE_BUFFER without using any code in DEFINE_PROGRAM, just use your STRING handler in the data event to trigger parsing the buffer.
I have a serial device which can regularly deliver strings above the 255 character limit that is being discussed.
I am currently receiving data from the device like this:
Should I consider filling the buffer Axcess style instead of DATA.TEXT?
What about strings from virtual devices to real devices and vice-versa over 255 characters?
Thanks!
From my understanding, if a CREATE_BUFFER was done, any data is immediately copied from hardware buffer to software, instead of the sBuffer = "sBuffer,DATA.TEXT" which requires an Event.
An Event is triggered if a break happens in the data stream, and the length of the break depends on the baudrate, it's not triggered by a "the string I received is complete".
While DATA.TEXT can receive upto 2048 characters in one event trigger, depending on NetLinx hardware you have 255 bytes (NI series) na 2048 bytes (NXC-COM2, NXI) hardware buffer for each serial port.
With receiving ethernet data, afaik this differs a little, because a IP packet is limited to 1000 bytes, and depending on the protocol (i.e. receiving a telnet terminal input) every character is an event.
Next is the virtual device or a physical device which sends strings.
If you have a touchpanel with a keypad, you will receive from it like 'AKEYP-123456'. Because this is sent by the panel on system level (within ICSP/AXlink protocol), you can be sure that this string is always a full dataset. So mostly it's not required to do a CRAETE_BUFFER to the panel and you can receive and operate that AKEYP- data in DATA.TEXT directly. This is also the same if you send and/or receive data in/from a virtual device. SEND_COMMANDs and SEND_STRINGs are always one dataset and they are always "complete" within the ICSP/AXlink protocol. But depending on the hardware (i.e. command length to a panel, terminal output) it may be required to split up the userdata into several parts.
Thanks![/QUOTE]
