NI-4100 Ethernet issue
in AMX Hardware
I had an interesting time today with a NI-4100 and an older Netgear 8 port 10/100 switch it was an xx-108 model).
WIth the ethernet mode set to auto, lights would blink, but no communication. Same if I tried to set it to 100 full or 100 half. Both 10 Full and 10 half worked. Everything else attached to this switch did OK with auto settings and ran fine at 100 full.
Replaced it with a newer D-Link and everything was good.
Had this problem several times most of the time with ni-x000 controllers.
Changing ethernet mode to 10Mb half solved most of the times the problem.
I even had the problem when conecting a wap-200 with a cross cable to a controller.
Two weeks ago i spoke someone from AMX who asked me if i filed in a gateway in the controller even if the controller is stand alone.
He told me to do that becuase with the new Duet firmware the controller seems to polling for devices. Since that i fill in the gateway on a controller on my desk an tryed every day for dropping connections. I must say that in the last week it happens just once instead of several times an hour. Maybe it's a solution for you all.
Good Luck
10 full and 10 half both worked without any problems, but the customer was afraid that 10 wouldn't be "fast enough" so we used his new switch.
