MIO-DMS Firmware Problem.
Just a heads up to anyone using the new MIO-DMS Keypads. There is a known problem in the firmware that will cause transfers to fail after sending the keypad file multiple times (I heard anywhere from 10-20 transfers before the problem). I believe that doing a clear all user files fixes the problem for another 10-20 transfers, but I never got to that point to verify this after a lockup. This is a known problem in the firmware and will be fixed with the next firmware release (I think).
There is also a problem with some fonts causing problems similar to the above. (this turned out to be my problem... I think). It might also be a problem with the keypad builder file getting corrupted. I was having problems transfering the keypad file and initially was told that it was the firmware problem.... but some investigation revealed that it might be the font problem. I changed all of the smaller point sizes to the default, and things got a little farther in the transfer, but still aborted due to being out of memory. I then watched which page was causing the failure and then removed the last page being transferred. I think I had to remove 2 pages, and finally everything transferred without problem. I was able to recreate the problem pages and transfer without issue. I was also able to use smaller point fonts and transfer without problems after removing the ?corrupted? pages.
Hope this saves someone else from a hair pulling fest.
P.S.
I will post my thoughts on the Keypad Builder program in the appropriate thread as well as my impressions of the MIO-DMS when I have some more time and don't have to play catchup from the above problem.
    Thx's Jeff for the heads up. I have done about 7-8 transfers now to a pad for changes that were requested by the user. Hope I can squeeze out 1 more ;)
  • mpullinmpullin Posts: 949
    Can't wait! I've just started to put some in. Until this thread appears I'm going to pass the time by going to Help -> About KeypadBuilder and counting the misspelled words :p
    P.S. Jeff, do you use NS or the KeypadBuilder program to do your transfers? My experience is sometimes using NS doesn't work right... but I haven't had a problem with KPB so far.
    I was using Keypad Builder to handle the transfers.
