RS232 and Room Groups
Ok, so I understand RS232 just fine, but I'm having problems understanding the instructions for grouping rooms together.
MSRGs,b8,b7,b6,b5,b4,b3,b2,b1
Create Room Grouping, where:
1) ?s? is the source to associate the rooms with
2) ?b8?... ?b1? is a binary room selection bitmap where all rooms to be grouped have a binary 1 in the room position. The most significant bit in ?b8? is for room 64 and the least significant bit in ?b1? is for room 1.
Notes:
1) A room grouping will be considered invalid if there are not at least two rooms selected for the group.
2) Only one room group can be associated with any given source.
So, my plan was to group some unused rooms together (7&8) when entering the source, and then immedietly adding in the other rooms as needed... So, if they had rooms 1, 3, and 6 grouped, the macro would look something like.
*create room group 7&8 on source 1*
*add room 1 to the group (MARG8,1)*
*add room 6 to the group (MARG8,6)*
*add room 3 to the group (MARG8,3)*
anyone able to explain the binary bit map thing? Basically, what will the string look like to make a group of 7/8... Like MSRG1,000000,000000,000000,000000,000000,000000,001000,000111
or what?
Notes:
or what?
Group 1, 3, 7, and 8 would be: 11000101
To make it easier, you could do this:
DEFINE_CONSTANT
INTEGER ROOM1 = $01
INTEGER ROOM2 = $02
INTEGER ROOM3 = $04
INTEGER ROOM4 = $08
INTEGER ROOM5 = $10
INTEGER ROOM6 = $20
INTEGER ROOM7 = $40
INTEGER ROOM8 = $80
SEND_STRING dvDEVICE,"'MSRG,",SOURCE,0,0,0,0,0,0,0,ROOM1+ROOM3+ROOM7+ROOM8)
The 0 just to the left of the ROOM additions would be for rooms 9-16, left of the would be 17-24, and so on.
Hope this helps,
MSRG1,255,255,255,255,255,255,255,255
To group zones 1, 3, 7, and 8 to source 1 would be as follows:
(the binary bitmask for 1,3,7,8 is 11000101)
(which written in decimal is 197)
MSRG1,0,0,0,0,0,0,0,197
Last night I spent 2 hour setting up an Escient Fireball AVX-552, Sony Changer and an FP-1 for the first time. Mapped network drives to iTUNES and other PC files to share music w/o any incidents. Today I've spent more than double that amount of time and I still not talking to this Matrix Audio P.O.S. You would think AMX could make their own equipment somewhat plug and play. Not to mention that once I do start talking this device I'll likely realize that the modules are crap and have to start from scratch.
Not happy!
It's not like I had any thing better to do last night than get aggrevated trying to talk to this deivce at the docemented baud rate. They could have put a sticker or taped a piece of paper with the new communication paremeters on the unit but no, that would make to much sense.
Each of the bytes from b8 to b1 contain 8 bits (each bit represents a zone). B1 represents the first 8 zones and b2 represents the second bank of 8 (zones 9-16), b3 is 17-24 etc.
MSRG1,0,0,0,0,0,0,0,192
--> create room group 7&8 on source 1 (Zones 7+8 = 11000000 = 128 + 64 = 192)
MARG8,1
--> add room 1 to the group
MARG8,6
--> add room 6 to the group
MARG8,3
--> add room 3 to the group
btw Jeff, great idea with the constants to do the calcs for you...
Try calling tech support and asking them to change the baud rate in the comm module and email the revised comm module to you. They did this same thing for me about a year ago when antex changed their baud rate on one of their receivers.
This was just a quick fix for a small job that originally had volume control which is why I used MA in the first place. I did spend a little more time making the attached GUI for it than I should have especially for likely a one time use. It's a little goofy but I wanted to try something different.
I recently just wrote a module for the Antex receivers as well with kind of an intersting GUI.
