External Button on MVP BUGS
hello ,
there is a bug on the external button on MVP non intercom
for example :
make a TPD4 with just a channel number (for example 15 ) on an external button , load file and push on the external button , and see in diagnostic
the Push on 15 go to 1 but never go down ( 0 ) and if u push again on this button nothing append
not good when u used external for volume control
  • vincenvincen Posts: 526
    Not good definitively :(
    Concerning non push generated on second time it's normal as master stores status of button, so if it has seen a push and not a release it'll not accept a second push without first a release ;)
    Vinc
  • i know but before it's working good
    Jiggle the center button on the nav cluster. I've seen many cases where this button gets stuck, and prevents the other hardware buttons from operating.
