G4 panel channel port
Hi,
does the Channel Port number in TPD4 work the same as the "Devices Used" option in TPD3?
Im programming a system which has a G4 panel as well as a G3 panel. I need more than 255 buttons so an extra device is needed, but i can't use button number >255 in TPD4 because then my G3 panel won't support them, hence the question
Regards,
Yuri
Regards,
Yuri
10001:1:0
10001:2:0
10001:3:0
10001:4:0
"Devices Used" will give you up to 4 total devices (255x4), but they won't follow the G4 buttons because they are virtual G3 panels.
128:1:0
129:1:0
130:1:0
131:1:0
So do something like
dev dvTP2[] = {10001:2:0,129:1:0,10002:2:0}
and then you can write code like:
button_event[dvTP2,[1-255]]
push:
and then it abstracts what the actual device numbers are...
