WebControl Not Working after IE7 Upgrade
Has anyone else experienced the WebControl Panels not working after an upgrade to IE7? When the actual window pops up for a panel you get a red X and the following error:
Line: 72
Char: 4
Error: Object doesn't support this property or method
Also, Firefox does not work either. I have tried both with the latest Applet runtime (v.6.1) and with a downgraded 1.4.2 runtime (as I read that might help).
Thanks for any insight.
  • I saw a technote on that recently. I'll dig it up and post for you. I think the workaround was to use VNC. We use tightVNC without any difficulties
    --John
  • Did a search a minute ago, didn't find it. This time I used a different search term and Bam!
    http://www.amx.com/techsupport/techNote.asp?id=804
    Edit: Actually it was related to a problem with a Microsoft security update (Microsoft KB916281). Still, hope this helps you out.
    --John
  • nhercnherc Posts: 34
    Thanks for the Tech. Note, but will this ever be fixed to work without the work around?
    Also, despite using a java applet (for multiplatform support I assume) will this ever support Firefox or Opera as well as IE?
    Thanks Again.
    It may not be officially supported, but I have used Firefox with web control successfully.
    Really? Do you have any specifics? My Firefox install only pulls up a blank new window where the panel should show up. It does not seem to error out however, so perhaps with the right Java runtime it'll function?
