Am I doing this right? (programmer 1 newbie)
I want to execute all this in one button push to turn a system basically can I just lay these out on a button event?
// system on routine
button_event [dvTP,10]
push:
on [dvrelay,screen_down]
wait 70
off [dvrelay,screen_down]
pulse [vdvVProj,27] //nec module (proj on)
wait 70
SEND_STRING dvSwth,'1*1!'
send_command vdvVProj, 'input-RGB,1'
  • This will execute more quickly:
    BUTTON_EVENT [dvTP,10]
       PUSH:
          ON [dvrelay,screen_down]
          PULSE [vdvVProj,27]                 //nec module (proj on)
          WAIT 70
          OFF [dvrelay,screen_down]
          SEND_COMMAND vdvVProj, 'input-RGB,1'
    --John
    Yes, but it won?t do the same thing.
    Only this line of code will be delayed for 7 seconds
    In the original posted code by avi_dave, these 2 lines will be delayed for 7 seconds:
    It depends on what you want to do. The syntax is fine and the code will execute. I don?t know if it?s with the delays you expect.
    If you want to use a WAIT to act upon more than one statement (one line of code), then you need to make it a compound statement by surrounding the statements within curly braces {}.
    WAIT 70
    //do this
    //do that
    //do the other thing
  • Looking back at my response, I'm not even sure what question I was answering...
       PUSH:
          WAIT 70
    Yes you can lay it out in a button_event.
    Code above does this:
    1) Screen Down, Projector On
    2) Wait 7 seconds
    3) Send '1*1' to the switch, and change projector to RGB input
    Original Code sent the change to RGB input too quickly.
    Thanks for the catch Joe (again :)).
    --John
  • flcusatflcusat Posts: 309
       PUSH:
          WAIT 70
    2) Wait 7 seconds
    --John
    You missed stop screen down in step # 3 before sending 1*1 to the switch.
  • Code above does this:
    2) Wait 7 seconds
    3) Stop screen down relay, Send '1*1' to the switch, and change projector to RGB input
    Happier now? :)
