Napco Gemini
Just updated the module and the password..all works fine for about 5 minutes then spits out these errors...
(0002518859) COMM RECEIVED FROM UI: ZONE_STATUS?2
(0002518861) NAPCO_FUNCTION(7,2) called
(0002518864) comm state is: 6
(0002518877) From Gemini-UI.axs UI RECEIVED FROM COMM: ERRORM=Queue 0x20 full 0x20 - 0x20 command 0x20 rejected.
(0002518878) SEC ERROR:Queue full - command rejected.
(0002518897) From Gemini-UI.axs UI RECEIVED FROM COMM: ERRORM=Queue 0x20 full 0x20 - 0x20 command 0x20 rejected.
(0002518898) SEC ERROR:Queue full - command rejected.
(0002518915) From Gemini-UI.axs UI RECEIVED FROM COMM: ERRORM=Queue 0x20 full 0x20 - 0x20 command 0x20 rejected.
(0002518916) SEC ERROR:Queue full - command rejected.
(0002518941) From Gemini-UI.axs UI RECEIVED FROM COMM: ERRORM=Queue 0x20 full 0x20 - 0x20 command 0x20 rejected.
(0002518942) SEC ERROR:Queue full - command rejected.
(0002518959) From Gemini-UI.axs UI RECEIVED FROM COMM: ERRORM=Queue 0x20 full 0x20 - 0x20 command 0x20 rejected.
(0002518960) SEC ERROR:Queue full - command rejected.
(0002518979) From Gemini-UI_.axs UI RECEIVED FROM COMM: ERRORM=Queue 0x20 full 0x20 - 0x20 command 0x20 rejected.
(0002518980) SEC ERROR:Queue full - command rejected.
(0002519044) From Gemini-UI.axs UI RECEIVED FROM COMM: ERRORM=Queue 0x20 full 0x20 - 0x20 command 0x20 rejected.
(0002519045) SEC ERROR:Queue full - command rejected.
(0002525832) From Gemini-Comm.axs COMM RECVD FROM DEV: 0x20 READY 0x20 0x20 0x20 0x20 04/22/07 0x20 12:59AMz 0x01 0x06 0x00 0xC
(0002525833) From Gemini-Comm.axs 0 0x0D 0xD4 0x01 0x06 0x01 0x83 0x00 0x8B 0x03 % 0x10 0x00 *ZONES 0x20 FAULTED** 0x20 0x2
(0002525834) From Gemini-Comm.axs 0 0x20 0x20 0x20 0x20 0x20 0x20 0x20 0x20 0x20 0x20 0x20 0x20 0x20 0x20 j 0x03 % 0x10
(0002525834) From Gemini-Comm.axs 0x00 13-MOTION 0x20 BY 0x20 0x20 0x20 0x20 0x20 FRONT 0x20 DOOR 0x20 0x20 0x20 0x20 0x20 w
(0002525835) From Gemini-Comm.axs 0x03 % 0x10 0x00 *ZONES 0x20 FAULTED** 0x20 0x20 0x20 0x20 0x20 0x20 0x20 0x20 0x20 0x20
(0002525836) From Gemini-Comm.axs 0x20 0x20 0x20 0x20 0x20 0x20 j 0x03 % 0x10 0x00 13-MOTION 0x20 BY 0x20 0x20 0x20 0x20 0x2
(0002525837) From Gemini-Comm.axs 0 FRONT 0x20 DOOR 0x20 0x20 0x20 0x20 0x20 w 0x01 0x06 0x00 0xC2 0x0D 0xD6 0x01 0x06 0x0
(0002525837) From Gemini-Comm.axs 1 0x82 0x00 0x8A 0x03 % 0x12 0x00 SYSTEM 0x20 READY 0x20 0x20 0x20 0x20 04/22/07 0x20 12:59A
(0002525838) From Gemini-Comm.axs Mz 0x03 % 0x12 0x00 SYSTEM 0x20 READY 0x20 0x20 0x20 0x20 04/22/07 0x20 01:00AMj 0x01 0x06 0x0
Any ideas??
Any ideas??
I've only actually integrated a Gemini once in my career, and I haven't had any trouble with it. The module I used was older than the hills, but I wrote my own UI for it, and just used the comm module.
Version 1.4 of the Gemini module utilizes updated handshaking in the device's firmware and fixes a lockup problem similar to what you describe. The new module is only valid for for the following firmware versions though:
GEM-P3200 ? 40B and later
GEM-P9600 ? 30B and later
GEM-X255 ? 4A and later
This module will not work on earlier firmware versions. Because of this handshaking change, the cable used to connect to an AMX master is now a 3-wire instead of a 5-wire. Continuing to use a 5-wire may cause additional problems.
If you're already using a 3-wire cable with one of the firmware versions listed above and rebooting does not clear the error, then I recommend contacting AMX Tech Support and reporting the problem.
As an aside is it worth it to me at some point to ditch the module (the programmer hates them) and let him program the whole thing from scratch?
On a side note, I believe that most modules are written to attempt to support the same commands so that even if you switched to a different brand security panel, simply switching the comm modules should still allow 80-100% functionality (depending on the supported features of each panel).
Yes. Reverse engineer the module to help get the protocol right and learn the tricks that the module programmer already learned for you.
(0002311249) From Gemini-UI.axs UI RECEIVED FROM COMM: ERRORM=Queue 0x20 full 0x20 - 0x20 command 0x20 rejected.
Thank you for the feedback. Someone will be looking into this right away.
Yes, we are working on version 1.5 of the module now. Be looking for it in the next few days.
Essentially, the new firmware versions have a new handshaking capability that the module was updated to handle. This required a change in the cable. There were a few problems with the implementation that were not discovered until they were tested in the field. It appears that all issues have been fixed except for the issue with the X255, which is a firmware issue not a module issue. The website has been updated to include the new cable and the module revision notes.
