Mio Classic Keypads & Hold
I was working on getting the hold for the volume up & volume down ramp on the new Mio Classic keypads with no luck.
I programmed it like you would the old 8 button keypads but as I hold the button down I get nothing any ideas?
example:
BUTTON_EVENT[dvKeypads,nKeypad_Buttons]
    PUSH:
	nPanel_Index = Get_Last(dvKeypads) + 5
	nPanel_Address = nPanel_Index + 144
	nButton = Get_Last(nKeypad_Buttons)
	Switch(nButton)
	    CASE 6:	/// Volume Up
		/// command to send volume up
		BREAK
	    CASE 7:	/// Volume Down
		/// command to send volume down
		BREAK
    HOLD[2,Repeat]:
	Switch(nButton)
		BREAK
		BREAK
using an ada suite 16 switcher
    Not sure that this applies, but if you are trying to accomplish this in a module, it will only see the HOLD events on the first instance of the module. The only fix I am aware of at this time is to save the module with multiple names (one for each instance).
  • Do you see a release, and if so when?
    You could set a flag value between push and release and use a 2/10 sec timeline to do the hold programmatically.
  • ondrovicondrovic Posts: 217
    Thanks for the replies I will give your suggestions a shot and see where it leads me.
  • GSLogicGSLogic Posts: 562
    You want to trigger the PUSH action on the RELEASE, unless you HOLD the button.
    Add the variable nPushOnly above:
      PUSH:
      HOLD[2,Repeat]:
    	nPushOnly = 1;
    	Switch(nButton)
      RELEASE
    	if(nPushOnly == 0)
    	  Switch(nButton)
    	else
    	  nPushOnly = 0;
    Thanks GSLogic I will give that a try
    Just wanted to report back and say thanks. GSLogic what you proposed worked great thanks for the help.
