Lexicon serial problems
Hi guys
I am working with MC-8 ver 2 .
The AMX module is working only with MC-8 ver 1...
The program that came with the module sent properly only few command.
I am trying to work with the serial command with no success..I am sending command like this:
Set Volume - SEND_STRING dvLexMC8, "'$F1,$04,$40,$01,$01,$F2'"
its not working...
I am also trying to understand how to change input and the document is not clear to me. every company has it logic, and this one is so not clear I don't understand what they want...
http://www.lexicon.com/downloads/mc8/MC8SerialDefRev1.pdf
thanks of any help
Ady.
  • adysadys Posts: 395
    Ok, we found a solution - to use the "Ir Codes" commads via serial commands. nice solution.
    We have a strange problem:
    DATA_EVENT[dvLexMC8]
    ONLINE:
    SEND_COMMAND DATA.DEVICE,'SET BAUD 19200,O,8,1'
    STRING:
    local_var char cLCD_DATA[64];
    cLCD_DATA= DATA.TEXT
    SEND_STRING dvDebug, "'lexicon string'"
    SEND_STRING dvDebug, DATA.TEXT
    } // END OF - string event
    } // END OF - data event
    The device is not sending strings to the data event...
    but If we connecting it with a serial cable to the terminal program - we can see that its sending string on the serial port.
    the code is the same for a lot of other serial devices.
    Any idea how to start solving this?
    thanks
    Ady
  • SEND_STRING dvDebug, "'lexicon string'"
    SEND_STRING dvDebug, "DATA.TEXT"
    Did you remember the quotes in your actual code?
    yes..
    The code don't reach there at all, not even with the a debugger.
    Netlinx studio notifications window also don't work.
    Only when connecting with a cable via terminal its sending some strange characters...
    I can understand that maybe there is some porblems in the code, but why the notifications window don't show the coming strings?
    Problems Solved
    I changed the line
    SEND_COMMAND dvLexMC8, 'SET BAUD 19200,O,8,1'
    to be
    SEND_COMMAND dvLexMC8, 'SET BAUD 19200,O,8,1 485 Disable'
    and now it working like it should...
    Why is that?
    I messed with it 2 days just to find out this 485 disable .. this is not written anywhere :(
  • adys wrote:
    I changed the line
    to be
    Why is that?
    Should both work, the '485 DISABLE' or *ENABLE*is optional (but must be written uppercase). For RS232 control (pins 2,3,5), it also doesn't matter if 485 mode is enabled or disabled (it's just a different handling of the data sent and received on pins 1,4,6,9). Maybe it's some kind of side effect if a full patched com cable is used and 485 mode was ON.
