NetLinx Studion ICSP Connection
hi together
i have problems to connect to my Master true a firewall (in my office).
the 1319 Port is blocked in this fw. so i make a NAT on my firewall at home.
first i test wich ports are open from inside to outside my office firewall. when i configure a website at my homeserver on http://mydomain:8888, so i can reach this side from my office. But when i set the ICSP Connection from office 8888 to home at 1319(NAT) it doesn't work !
i test my NAT on a different private LAN and the NAT is working correct, i can connect to the master.
Question: is there also a UDP on 8888 needed or what else can it be?
thanks for help.
John
  • jweatherjweather Posts: 320
    No UDP needed, just TCP. If you're using NetLinx Studio to connect, be sure to turn off "Ping master to ensure availability" in the Communication Settings dialog.
    Jeremy
  • Hi Jeremy
    thanks for your answer.
    only tcp?! :-(
    ping is already deactivated! what else can it be? i thing tcp on port 8888 is the same with the browser and netlinx studio....
    any other hints?
    thanks
    john
