Mio Classsic Question
BUTTON_EVENT[dvKeypads,nKeypad_Buttons]
	Steps
	1. Check the power state
	    Is the Power off or on?
		a. Power is off
		    i. Turn on system; switch to correct source
		b. Power is on
		    Was the source that was just selected the same source or a different one?
			i. Same Source
			    a. Do source function; change preset, track, etc
			ii. Different source
			    a. Switch to correct input
    PUSH:
	nPanel_Index = GET_LAST(dvKeypads) + 5
	nPanel_Address = nPanel_Index + 144
	nButton = GET_LAST(nKeypad_Buttons)
	//nPush = nPush + 1
	debug("'MIO Keypad : ',ITOA(nPanel_Address),' - What is the current power state?'")
	SELECT
	    ACTIVE(strWhPwr[nPanel_Index] = 'F' AND nButton < 5):
		debug("'MIO Keypad : ',ITOA(nPanel_Address),' - The power is off!'")
		debug("'MIO Keypad : ',ITOA(nPanel_Address),' - Turning the power on!'")
		debug("'MIO Keypad : ',ITOA(nPanel_Address),' - Which zone?'")
		ON[nPanel_Address,nButton]		/// Feedback for button #'s 1 - 4
		strWhPwr[nPanel_Index] = 'N'		/// Set room power state to on
	    ACTIVE(strWhPwr[nPanel_Index] = 'N' AND nButton < 5):
		debug("'MIO Keypad : ',ITOA(nPanel_Address),' - The power is already on!'")
		debug("'MIO Keypad : ',ITOA(nPanel_Address),' - What source was selected?'")
		IF(nPush > 1)
		    nPush = 0
		    debug("'MIO Keypad : ',ITOA(nPanel_Address),' - Same source pushed!'")
		ELSE
		    debug("'MIO Keypad : ',ITOA(nPanel_Address),' - Differenet source pushed!'")
		PULSE[nPanel_Address,nButton]		/// Feedback for button #'s 1 - 4
		WAIT 5
	    ACTIVE(nButton = 5):
		debug("'MIO Keypad : ',ITOA(nPanel_Address),' - Power off selected!'")
		debug("'MIO Keypad : ',ITOA(nPanel_Address),' - Which Zone?'")
		ON[nPanel_Address,nButton]		/// Feedback for button # 5
		strWhPwr[nPanel_Index] = 'F'		/// Set room power state to off
I am trying to program for the MIO Source buttons. I need it to do the following:
1. Check the power state [done]
Is the Power off or on? [done]
a. Power is off [done]
i. Turn on system; switch to correct source[done]
b. Power is on [done]
Was the source that was just selected the same source or a different one? [done]
i. Same Source
ii. Different source [done]
With the above code I am having I need it to do the source function until the source is change to another source. What I am running into to is, that it works fine for the 1st & 2nd push, but after the second push it resets nPush = 0 and starts over.
I guess my question is how do you setup the code to do the source function ( next track, preset, etc ) until the source is changed?
Thanks for the help
Chris Ondrovic
  • ondrovicondrovic Posts: 217
    I figured it out guess it just took me to take a step back.
    If anyone else wants to know how i did it here is the code
    	Steps
    		a. Power is off
    		b. Power is on
    			i. Same Source
        PUSH:
    	SELECT
    		IF(nCur_Source = nButton)
    		ELSE
    		WAIT 5
        RELEASE:
