NI_900 IR/RX Port?
Has any one used this? I can't seem to find any documentation on what this actually can or can not do. Is this strictly a repeater, IR in gets passed to the IR/Serial ports or can it do tricks? Like compare received IR strings and compare them to stored IR values and if it matches do something. I know that's probably asking for too much but that would be so nice to be able to make every ones favorite cable remote do basic system control. Power up, change channels and AVR volume control instead of TV volume control. I currently use the cable remote to power up the system by using a current sensor on the TV so when the TV powers on it turns the system on (watch cable mode) and then you just change channels. Works great for kids to keep them away from the MVPs but I can't change the volume w/ it. I've thought of trying the Xanteh IR to rs232 box but I believe that just works on Xantechs RC88 codes or something to that affect. Any thoughts? Any know what this IR receive port can do?
I think it was more like the idea that you could use this to control a small room or a projector area that was part of a larger system, and it could then provide an IR receiver for local control. Your basic boardroom, for example, might have a projector or a monitor, and a DVD player; an NI-900 or 700 would be perfect to control the minimal amount of equipment, and you just tack on an IR remote to control it.
From a sales perspective on the one hand AMX might be able to sell more NI-900s but on the other hand they might sell less Remotes and TPs. They probably make more on the latter.
