Colour picker code.
The internal colour picker on the touchpanels is not transmited to the master.
So I wrote code to take three floats in the range 0.0 to 1.0 as a hsl colour, and create rgb colour in hex to send to buttons and use to drive lighting control from the DMX512 box.
Heres my code and the main function for those who had similar requirements.
DEFINE_FUNCTION HSLtoRGBHex(FLOAT HSL[], CHAR hexrgb[])
FLOAT temp1, temp2, t3[3], clr[3]
INTEGER index
INTEGER red, green, blue
IF(HSL[3]=0.0)
clr[1]=0.0
clr[2]=0.0
clr[3]=0.0
ELSE
IF(HSL[2]=0.0)
clr[1]=HSL[3]
clr[2]=HSL[3]
clr[3]=HSL[3]
ELSE
IF(HSL[3]<=0.5)
temp2 = HSL[3]*(1.0+HSL[2])
ELSE
temp2 = HSL[3]+HSL[2]-(HSL[3]*HSL[2])
temp1 = (2.0*HSL[3])-temp2
t3[1] = HSL[1] + 0.3333
IF(t3[1] < 0.0) t3[1] = t3[1] + 1.0
IF(t3[1] > 1.0) t3[1] = t3[1] - 1.0
t3[2] = HSL[1]
t3[3] = HSL[1] - 0.3333
IF(t3[3] < 0.0) t3[3] = t3[3] + 1.0
IF(t3[3] > 1.0) t3[3] = t3[3] - 1.0
FOR(index=1;index<4;index++)
IF((6.0*t3[index]) < 1.0)
clr[index]=temp1+((temp2-temp1)*t3[index]*6.0)
ELSE
IF((2.0*t3[index]) < 1.0)
clr[index]=temp2
ELSE
IF((3.0*t3[index]) < 2.0)
clr[index]=(temp1+((temp2-temp1)*(0.6667 - t3[index])*6.0))
ELSE
clr[index]=temp1
red = TYPE_CAST(clr[1]*255.0)
green = TYPE_CAST(clr[2]*255.0)
blue = TYPE_CAST(clr[3]*255.0)
hexrgb = "FORMAT('%02X', red),FORMAT('%02X', green),FORMAT('%02X', blue)"
LEVEL_EVENT[TP,1] // Hue 0 - 255
LEVEL_EVENT[TP,2] // Sat 0 - 255
LEVEL_EVENT[TP,3] // Lum 0 - 255
CHAR RGBH[6]
// store hsl colour in global
TPHSLColour[level.input.level] = level.value/255.0
// convert to RGBHex
HSLtoRGBHex(TPHSLColour, RGBH);
// make command to set button 1 to the picked colour
SEND_COMMAND TP, "'^BCF-1,0,#',RGBH"
the colour picker code is transmitted to the master
check this out
http://amxforums.com/showthread.php?t=2594
I can see trav's code that requires a button press to get the colour.
And your reply about your code but I don't see your code!?
here it is
Cheers for that
check out the little dot on the left bottom corner of the colour picker. That's actually the button i'm copying to
