VPT-CP firmware v5.01m and TPDesign3
jmhjmh Posts: 4
Is this firmware compatible with TPDesign3? I can't seem to get a serial connection to work.
  • travtrav Posts: 188
    9 times out of 10 I couldn't (past tense as I now tell people when they ring up that they are 'no longer supported' ) connect was because I was have a brain fade and didn't use my crossover cable.
  • jmhjmh Posts: 4
    Yep... wiring issue
    Thanks; you were right
    I made my own cable from http://www.amxforums.com/showthread.php?t=2126&highlight=vpt-cp
    However, the following is for a straight through cable, not for use with a crossover:
    2 - tip
    3 - ring
    5 - sleeve.
    If you use this configuration, you don't need a crossover cable.
    I hope this helps anyone in the future who has to make their own cable. Parts from Radio Shack listed below
    Catalog #: 276-1539 9- and 15-Position D-Sub Connector Hood
    Catalog #: 274-244 RadioShack Gold Series 3/32" Stereo Plug
    Catalog #: 276-1537 9-Position HD Male Solder D-Sub Connector
    Cool, glad you got it sorted :)
