get_last
adysadys Posts: 395
Is its safe to call get last from a function that called from the EVENT and not inside the Event code itself?
I mean if I have button event, and in the button event I call to function doX that call to function doY. inside doY i need the Tp that cause the event, so I call get_last with my global TP_LIST.
That works ok, I just wonder if that is safe and if what will happend if some event will enter in multiy TP enviroment.
thanks
Ady.
  • GSLogicGSLogic Posts: 562
    Pass the TP number to the function, this way you can have multiple panels using the function.
    DEFINE_FUNCTION whatEver(integer nPNL)
      //nPNL is your get_last panel number
    BUTTON_EVENT[dTP,btArray]
      PUSH:
         whatEver(get_last(dTP));
  • adysadys Posts: 395
    That what I am trying to avoid :)
    I have lots of written code that need to be changed - or to pass the TP or just to call get_last.
    The question is if it safe, if there is a kind of build in protection on it
    I'm not really sure what you are asking but, you should have all events/functions look to the TP that triggered the event. If you are working in a large system with many TPs this is a MUST! It is good practice to store feedback in a structure and only send feedback to TPs that need to be updated.
    I am just asking if its safe to ask get_last after some time that the event happend?
    Or maybe I can get the new event data (event that I am still on the flow of the first event)?
    An example:
    BUTTON_EVENT
    get_last.
    call Function X
    call Function Y
    Function Y Body
    get_last
    There is a chance that in the time between the button event and the get_last call inside function Y a new event will trigger.
    The question is, what get_last will return? the new event TP of the current event TP?
    No, it's not safe. The value could have changed. In many cases, it's not likely, but it is possible. The best practice is to keep get_last inside the event handler, and pass the return value to your function.
    Thanks, that what I wanted to know.
    Isn't that in a sense what the code snippet that GSLogic provided below does. The get_last function w/in the whatever function occurs in the Button_Event and its returned value is passed to the function whatever.
    Code:
      PUSH:
    }__________________
