Channel Vision P-1420 Matrix ?
Hi,
Interested to know if someone succeeded to control an A/V matrix P-14200 manufactured by Channel Vision ?
There is a strange checksum to calculate
All the more manufacturer is unable to explain himself protocol !!
Thanks for any tips, infos you might have
Vinc
Vinc
Here it is
It looks like their doing a 1s complement Check sum.
The idea is that you add the hex values of the string, then (if the value goes over 8 bits) truncate the result back to 8 bits. (ex: if the result is $14F, then you ditch the 1 with the result of $4F)
Then do the 1s complement.
It's an inversion of the result.
So, using our example of $4F:
$4F = 0100 1111 binary
1s complement or inversion is easy. Just go through the binary number and make every zero a 1 and every 1 a zero.
so
0100 1111 inverted = 1011 0000
and
1011 0000 =$B0
So, the check sum is $B0
There ya go!
The easiest way to do this is using bitwise XOR with a full set of on bits:
cResult = ~cSum
Thanks to all of you for all your explanations and details. I thought I would kill myself as nothing worked, and no answer from that damn product, and support nearly nothing at Channel Vision.
But after three days harassing their tech support, we finally succeeded to get the engineer that developed the matrix and we discovered that it exists two versions of protocol
That one is really simple and straightforward, for example:
and the best it works really
Thanks again to all, have a great end of day and week-end
Vince
I suppose I could have put the NetLinx way of doing this. I only covered the theory behind it. I prefer the Bitwise BNOT command method. it is the same as the old Z80 BNOT command which is where the 1s complement checksum came from in the first place.
I forget sometimes that many programmers today have never even seen where a lot of this stuff came from. Sheesh, I'm getting old!
Well, the I can tell you that experience is colored gray...
