VPT-CP and IR string repeat on button hold
Does anyone know of a way to 'repeat IR on hold' on a button? An example would be for a volume up button, that you want to continue to pulse as long as it's held down.
ie:
$P 10 1 <CR>
How can I get the button to repeat this if I hold it down?
Thanks in advance.
ie:
$P 10 1 <CR>
Thanks in advance.
I'm only using a VPT-CP and am entering the script in the button properties and using IR library loaded directly onto the panel; no controller. Is there some way to do this considering my scenario?
You may have to assign the IR channel directly to the button for this.
Kind regards,
