MVP-8400i Sound
vining
I've been working w/ 2 new MVP "i" panels and have notice that the sound on the button pushes often give an odd crackle type of sound with the normal button push hit or miss sound. It sounds like crap. Has any one notice a similar odd sound with these or possible the "i" series in general.
I'm thinking about shipping these back for replacement if this isn't a new low quality norm.
On a happier note, the intercom appears to work rather nicely with the module. Of course I bought a IP intercom from Digital Acoustics but haven't been able to make them talk with the TPs, although they are pretty cool all on their own.
From feature list:
Corrected an audio bug that prevented doorbell tones from playing properly
Try another sound file.... there are many on web for free... and see for your self.. if it is odd, then send it back, if it is fine....... then it is you ...
I did. The symptoms are much improved, but in the setup pages, it's worse. Not that the customer is typically there though.
I have exprienced exactly the same symptoms on just about every Modero panel I have worked on. (maybe a dozen or so) Latest firmware is installed.
I agree that it sounds more like a processor hang than an amplifier overload.
I was having the same problem, and even after updating the firmware, but later then , the compact flash has been corupted, and they sent me a new one with a firmware already installed in it Version 2.81.21..... The sound is perfectly fine.
I assume that this firmware will be released soon.
This version isn't necessary will fix vinings issue, but may be , who knows??
