Multiple touch panels on same frequency
Can this be done? I have two panels (vpt cp) that operate on the same frequency but I'd like to have them run independent programs, how do I go about this?
Dan
Dan
- Chip
Thanks!
Dan
Hey, I believe that they are saying to set the channel of the button being used. If I remember correctly (it's been a little while, sorry) you have the option of of 4 channels on the VP touch panels. So set all of the buttons for one system on button channels 1 & 2 with each having 255 addresses in each, and then set the buttons for the other system to 3 & 4. Please correct me if I am wrong or if this is not what you were saying. Thanks.
I thought what you are talking about was the device?
Dan
Ah, OK - that makes sense - thanks.
One last question then - I have my receiver set to 6001. TP device on 1. Base address is 128. What is the base address doing? I'm seeing all button presses on 6001 for that panel.
Dan
- Chip
Not axlink, phast...
OK thanks - I'll just mess around!
Dan
Dan
So maybe the Phastlink version is different, but perhaps the presses from buttons assigned to "device 2" on the panel would show up as 6001:2:1?
- Chip
Well whats getting me confused is that I'm not actually seeing ANYTHING on the diagnostics. Anything on device 1 shows up fine, but device 2 buttons don't trigger anything. Go figure...
On one panel I have a bunch of buttons on device 1.
On another panel I have some more buttons on device 2.
Receiver is at 6001
I have defined the first tp as 06001:1:1.
I have defined the second tp as 06001:2:1
I get button presses from the first panel with no problems. I even get button presses from the second panel for buttons defined on device one. However anything defined as device 2 gets me nothing. What am I doing wrong?
Dan
correct me if I'm wrong, but doesn't the old G3 TPs achieve 2nd, 3rd and 4th devices not at the port level but at the device level?
So, in your case shouldn't device 2 be at 6002:01:0?
I've used the old G3 panels wired via Axlink or Axlink wireless 100s of times. so those end up being something like...
TP_1_1 =128:01:0
TP_1_2 =129:01:0
TP_1_3 =130:01:0
TP_1_4 =131:01:0
(... some device below 255:01:0)
I've never tried to repurpose the TPs with phastlink/ICSNet. So, my advice might be totally off base.
I think I might have found my problem, it looks like maybe VPT-CPs do not support anything other than device one? Is that the case?
- Chip
--John
I love the implied (old) guys
I don't relish the old days of TPD3. It didn't have an undo. That was infuriating...
