Address and Channel???
Can somebody give me a quick overview of the differences between Addresses and Channels and how they relate to feedback to and from a master? The help documentation in TPD4 seems woefully inadequate for newbies and doesn't give a good explanation. I'd settle for a URL to some good documentation on the subject if you know of any.
Thanks for the help,
Derek.
Derek.
BUTTON_EVENT[tp_1,1] { PUSH: { // some one pushed button 1, do someting. someone_did_something=1 } }Channels are also used for feedback.
DEFINE_PROGRAM IF(someone_did_something=1) { ON[dv_tp,1] // TURN ON THE FEEDBACK OF BUTTON 1 someone_did_something=0 // reset the var }NOTE: turning a touch panel button channel on does not equal pushing it.
The Address portion is typcially used for variable text.
So,
IF(someone_did_something=1) { ON[dv_tp,1] // TURN ON THE FEEDBACK OF BUTTON 1 SEND_COMMAND dv_tp,'TEXT1-HEY! Stop pushing this button!" someone_did_something=0 // reset the var }Note: The Address number doesn't have to be the same as the channel number. It could be button Channel 1 and Address 101. If that were the case the above example would look like..
IF(someone_did_something=1) { ON[dv_tp,1] // TURN ON THE FEEDBACK OF BUTTON 1 SEND_COMMAND dv_tp,'TEXT101-HEY! Stop pushing this button!" someone_did_something=0 // reset the var }Sorry to use old programming methods, but sometimes it's the easiest way to explain it...
