Dynamically adding items to a DEV array
mstocum
I'm working on rolling my own AMX monitoring system since from what I've seen of RMS it's over kill for what my needs are (and I don't like the thought of running a Windows server for a web app). Anyway, for my first tests I was just trying to monitor the power state of a display. Now if I use a CHANNEL_EVENT to monitor [33001, 255] directly, I see the ON and OFF events like I would expect. This of course isn't very modular, so my ultimate goal is to have an array of devices and monitor 255 on that array ie:
The problem is that this doesn't do anything, the code in ON and OFF never gets called. dvMonitoredDevices is a VOLATILE DEV array. I'm wondering if part of the problem may be how I'm adding devices to the array. My code is as follows:
I've also tried all of this using a DEVCHAN array just in the off chance that a CHANNEL_EVENT required it and I got the same results.
Anyone have any ideas?
Matt
CHANNEL_EVENT[dvMonitoredDevices, 255] { ON: { // Report device on } OFF: { // Report device off } }
DEFINE_FUNCTION registerMonitoredDevice(CHAR sDev[]) { STACK_VAR INTEGER nArraySize STACK_VAR DEV dvDev dvDev.NUMBER = ATOI(sDev) REMOVE_STRING(sDev, ':', 1) dvDev.PORT = ATOI(sDev) REMOVE_STRING(sDev, ':', 1) dvDev.SYSTEM = ATOI(sDev) nArraySize = LENGTH_ARRAY(dvMonitoredDevices) dvMonitoredDevices[nArraySize + 1] = dvDev SET_LENGTH_ARRAY(dvMonitoredDevices, nArraySize + 1) }
Matt
2) SET_LENGTH_ARRAY can't make an array longer than it was originally declared, it can only change the size within that range. Try to guess how many devices you'll ever want to monitor and make your array that size. We're not dealing with vectors here.
Because the device to be managed is coming in through a SEND_COMMAND to a module, so it has to come over as text.
That's what I'm doing (I think). I declare a 64 element empty array, so it's length should be 0, each time I add something to the array I get the length, and then add an item to length + 1. I have no idea if the call to set_length_array is needed or not, but it seems like it shouldn't hurt.
Also, have you tried manually defining the array and seeing if you get the desired feedback then? That would be my first step. Then you're sure to narrow down the problem to your procedure for adding devices.
I'll try both later today. The room is in use right now and I think people would notice the system rebooting itself. I really don't know why I didn't think of adding the entries by hand earlier. Guess after a couple hours of banging your head against a problem you start missing obvious things.
I'm not sure how REBUILD_EVENT() would help with the CHANNEL_EVENT not being called. It does look like something I should probably call at the end of the event though.
The event table for the channel event will only contain the devices in dvMonitoredDevices that were there at compile time(and hence only triggered by these devices) unless you call rebuild_event() to rebuild the event table using the new devices added by your registerMonitoredDevice() function.
Hope that makes sense.
Ahh, yes that does make sense. And it also fixed the problem and made everything work perfectly.
Could you explain the 255 bit please? Are you sure you shouldn't be using 0 instead, to collect all channels? I believe that specifying 255 means you only get channel 255.
After taking into account the other comments posted here, the code above appears to be good, and it is the way that AMX expects you to do this kind of thing. However anyone who has coded in a couple of dozen other languages will find it appalling - and unnecessarily complicated.
Here is how I would instinctively do it:
And here is the routine I call for all arrays during startup:
In AMX, understanding REBUILD_EVENT is the working at the level of deepest wisdom
This is the reason that my code didn't work?
I wanted to call to a function that getting a list of DEV with a single DEV. ( in short, I wanted to made lots of updates in the local TP and only when done (release event) to send update to all the rest)
I done something like this:
BUTTON_EVENT[BUTTON,tpList]
DEV tempList[1]
Panel = get_last(tpList)
tempList[1] = Panel
Function(tempList)
Function(tpList)
The first call did nothing... even that I saw with the debuger that the temp list holds the values of the Panel.
From what I reading here I needed to do a rebuild event?
I don't see why, but its the same problem (only my code is from button event and not channel)
