Stacking CASES?
vining
                    I saw this style used in a module some where and of course it first confused me.  Yeah, I know it's not complicated but it was different and new to me.  Once I understood it I began to like the method, the simplicity and have been using it quite alot ever since and I don't believe with any ill affects.  But I also never thought putting a HOLD in a buttn_event of a DEV Array was bad either.
Does any one else do this? Is this method of stacking cases so that when there's a match it falls through to the first brace with a statement to execute a good thing or a bad thing. Are there any issues like putting HOLDS in dvArray button_events that may creep up and bite me in the .... that I'm not aware of.
                            CASE 10:	//
			      fnRefreshTP_Image(cCurUS_Sat_View,US_SAT_LG_VT) ;
			      break ;
			 CASE 11:	//SAT REQION SELECTIONS 'ABQ',   //1
			 CASE 12:	//SAT REQION SELECTIONS 'AK',    //2
			 CASE 13:	//SAT REQION SELECTIONS 'ALB',   //3
			 CASE 14:	//SAT REQION SELECTIONS 'AUS',   //4
			 CASE 15:	//SAT REQION SELECTIONS 'BWI',   //5
			 CASE 16:	//SAT REQION SELECTIONS 'CARIB', //6
			 CASE 17:	//SAT REQION SELECTIONS 'CLT',   //7
			 CASE 18:	//SAT REQION SELECTIONS 'COD',   //8
			 CASE 19:	//SAT REQION SELECTIONS 'DEN',   //9
			 CASE 20:	//SAT REQION SELECTIONS 'DTW',   //10
			 CASE 21:	//SAT REQION SELECTIONS 'EVV',   //11
			 CASE 22:	//SAT REQION SELECTIONS 'GULF',  //12
			 CASE 23:	//SAT REQION SELECTIONS 'HI',    //13
			 CASE 24:	//SAT REQION SELECTIONS 'ICT',   //14
			 CASE 25:	//SAT REQION SELECTIONS 'LAS',   //15
			 CASE 26:	//SAT REQION SELECTIONS 'LIT',   //16
			 CASE 27:	//SAT REQION SELECTIONS 'LWS',   //17
			 CASE 28:	//SAT REQION SELECTIONS 'MGM',   //18
			 CASE 29:	//SAT REQION SELECTIONS 'MSP',   //19
			 CASE 30:	//SAT REQION SELECTIONS 'PIR',   //20
			 CASE 31:	//SAT REQION SELECTIONS 'TPA',   //21
			 CASE 32:	//SAT REQION SELECTIONS 'WMC'    //22
			      cGetRegion = Sat_RegionArry[nBTN - 10] ;
			      break ;
			 CASE 33:	//SAT IMAGE TYPE 'vis',   //1
			 CASE 34:	//SAT IMAGE TYPE 'ir',    //2
			 CASE 35:	//SAT IMAGE TYPE 'wv',    //3
			      cGetImageType = Sat_ViewArry[nBTN - 32] ;
			      break ;
			 CASE 36:       //SAT IMAGE TYPE 'vis',   //US_Sat_VLarge
			 CASE 37:	//SAT IMAGE TYPE 'ir',    //US_Sat_VLarge_IR
			 CASE 38:	//SAT IMAGE TYPE 'wv',    //US_Sat_VLarge_WV
			      stack_var char cTempResource[16] ;
			      SWITCH(nBTN)
				   CASE 36:{cCurUS_Sat_View = 'US_Sat_VLarge' ;}
				   CASE 37:{cCurUS_Sat_View = 'US_Sat_VLarge_IR' ;}
				   CASE 38:{cCurUS_Sat_View = 'US_Sat_VLarge_WV' ;}
			      cTempResource = cCurUS_Sat_View ;  //put in temp buffer cuz function deletes/removes the value
			      fnRefreshTP_Image(cTempResource,US_SAT_LG_VT) ;
			      break ;
	       ACTIVE (nBTN > 49 && nBTN < 86):
"BREAK also jumps to the end of a SWITCH statement."
I've never done this myself. I always felt like a case is going to fall through anyway. I don't hang around in them long enough for the variable to change mid-stream.
If you're referring to the stacked Cases with nothing in them, I suppose they complile the same as.
Case 11:
break ;
Case 12:
break ;
Case 13:
break ;
etc...
interesting...
I would wonder why they wouldn't have chosen to use a select<>Active or even a simple If(bla bla bal) It'd be less typing. Perhaps it's just leftover warm-fuzzies from programming in BASIC back in da day but I still use IF() statements a lot. Switch/Case also. Select/Active not so much...
I even didn't stop to think, I use to do that for year in C++.
Am I wrong or in netlinx you don't need break command for switchs?
And what is the HOLD issue?
Nope! I'm anal w/ OCD!
The HOLD!
http://www.amxforums.com/showthread.php?t=2590
I would be inclined to code this:
CASE 36: //SAT IMAGE TYPE 'vis', //US_Sat_VLarge CASE 37: //SAT IMAGE TYPE 'ir', //US_Sat_VLarge_IR CASE 38: //SAT IMAGE TYPE 'wv', //US_Sat_VLarge_WV { stack_var char cTempResource[16] ; SWITCH(nBTN) { CASE 36:{cCurUS_Sat_View = 'US_Sat_VLarge' ;} CASE 37:{cCurUS_Sat_View = 'US_Sat_VLarge_IR' ;} CASE 38:{cCurUS_Sat_View = 'US_Sat_VLarge_WV' ;} } cTempResource = cCurUS_Sat_View ; //put in temp buffer cuz function fnRefreshTP_Image(cTempResource,US_SAT_LG_VT) ; break ; }like this:
case 36: { NewFunctionCall('US_Sat_VLarge') } case 37: { NewFunctionCall('US_Sat_VLarge_IR') } case 38: { NewFunctionCall('US_Sat_VLarge_WV') } define_function NewFunctionCall( char sArgSomething[]) { stack_var char cTempResource[100] cTempResource = sArgSomething (* put in temp buffer cuz etc *) fnRefreshTP_Image(cTempResource,US_SAT_LG_VT) }I would also change fnRefreshTP_Image because mangling the arguments sent to you is very bad practice. This would make NewFunctionCall redundant.
