Home AMXForums Archive Threads AMX Hardware MAX by AMX
Default aspect ratio for MAX in the recent UI is backwards
Just got off the phone with tech support and in case this hasn't been mentioned before, the default aspect ratio as defined in the UI module is 4:3. So, when you are going crazy trying to figure out why the setting seems right but the default aspect ratio always defaults to 4:3, the setting in the UI module is backwards. 4:3 is 0, 16:9 is 1. No tech notes on this so here ya go.
