Trouble getting Caddx NX8E to work
Anyone used the NX8E module on inconcert before? Having trouble getting it to communicate with my unit - I think I configured everything right but getting no feedback. Just curious if anyone's had any experience with it..
Dan
Dan
Make sure you review the programming notes with regards to setting keypad values on the alarm system.
Good Luck
They're all set...
--John
Thanks John
I tried with and without a null modem adapter. I actually made my own cable way back when. I had the NX8E hooked up to a Premise system. Just to test I reconnected it to that system and Premise was able to communicate with the unit fine, which tells me it is not my cable or my system. However when hooked up to my AMX system it doesn't seem to want to communicate. The module keeps timing out with "no response received." Pretty stumped...I'd love anything you could throw my way...
As always, start by controlling the box directly from your keyboard using HyperTerm. If that won't work then it's not the module's fault.
Double check these for security and safety specific to your application.
Our original P0003 cable only has 3 wires attached to the header of the NX8e (I believe 2,3, and 5), so I would make sure you don't have anything extra attached.
If you're still stuck after using our settings, then I would recommend calling GE tech support. Those guys really are great and very knowledgeable about their product. They'll get you up and running pretty quickly with regard to connection and config.
Let us know if these settings work for you.
--John
--John
Thanks a lot John, much appreciated. If you don't mind me bothering you some more, do you know what settings you changed (if anything) in the module? Also, did you take the stuff from the _Main file and put it into your master program? I could not get it to compile any other way, I'm guessing that was the intended usage?
Thanks again,
Dan
John,
You're awesome! I'm all up and running now. I think my problem was that I had it set to binary and not ASCII - that would be an issue! Again thanks for your help. Quite a helpful community here.
Now I'm working on figuring out why I have to enter a code to arm...
Feedback is also an issue, because of the amount of traffic generated. With 192 zones on the NX8e, you've got motion sensors turning on and off as people and animals move around, doors and windows being opened and closed, just a whole host of stuff going on. I'm trying to slow the feedback down now because the excessive amount of feedback that the module generates causes the Master to crash or drop offline under certain conditions.
Also I'm currently trying to add some non supported buttons such as scroll up, and scroll down and I'm also trying to figure out how to put the faulted zones into a displayable text list rather than lighting up 192 buttons and having the user flip through 12 pages of zone names to see which ones are faulted.
Any luck yet with our alarm config. settings? I passed by another project today to pull another setup configuration for the NX8e. I'll review the settings and compare them to the first ones that I posted to see if they're different.
--John
That's the quick arm feature - location 23 Segment 1 needs to be on to enable quick arming (arming without entering a code).
--John
Curious, is there an easy way to fire of an event based on a status change of a partition? For instance, I'd like to send off an email when the alarm is triggered. Is this easy to do or am I stuck rewriting the module?
Thanks again for all your help,
Dan
--John
Thanks John. Might someone be able to give me an example of what such a DATA_EVENT would look like? What would the trigger be?
Thanks again
Dan
