Clock Manager feature request
in AMX Hardware
Until recently I have been using i!-TimeManager to keep all my clocks synced. Now that I'm using RMS, the masters get their time from the RMS server (which in turn is synced to a time server). Synced clocks are great, particularly for trouble shooting across multiple platforms.
I've just updated some NI-3100 Duet Master firmware to v3.21.254. I see that there is a new "Clock manager" section. (I believe it was introduced a few firmware releases ago.) It has several modes, NetworkTime or StandAlone.
When using RMS or i!-TimeManager code for syncing, it would be nice for the Clock manager to be able to reflect this. Perhaps a few more "modes" which are only activated when the code running on the master sends a special string to the master.
I realise that such a feature would require changes to the firmware as well as the RMS/TM modules. However, the actual clock soureced is quite obtuse when programatically obtaining time, even with AMX provided modules. Perhaps I am just dreaming for a Utopian solution.
Roger McLean
Swinburne University
Roger McLean
I wrote a simple program that telnets into the NIST Time server. That server's time format is pretty much fool proof in the way it handles Daylight Savings Time. It also comes with a lot of other goodies like Julian Date, current server health, a very good estimation of the latency of your time request and when you get the response message. (If you're into that much accuracy...)
Open up a telnet session and hit 132.163.4.101 port 13 and see what you get. The Protocol is available online.
Hope that helps
