Compact Flash Throughput
in AMX Hardware
I wrote a TFTP utility in Duet. You can send and receive files with it. I get the following CF throughput on a ME260/64, as reported by the TFTP server:
SanDisk 1.0GB from Staples
The average at the end of a 12MB file transfer
TFTP Receive = ~28216 Bytes/sec (Write to CF)
TFTP Send = ~35373 Bytes/sec (Read from CF)
Does anyone have any CF throughput numbers using Netlinx code?
I tried it with a IBM 1GB micro drive:
The average at the end of a 12MB file transfer (as above)
TFTP Receive = ~32970 Bytes/sec Bytes/sec (Write to CF)
Read time was the same, which makes sense as Flash medium is slow to write.
So there was a ~4.7k Bytes/sec performance increase in write time between the two CF drives I tested.
