Little Problem with flag variable
This block of code executes everytime in many different jobs but I cant seem to figure out whats stopping it this time around, can I rewrite this and still end up with the same timing and function
Code:
button_event [dcPhSpdDial]
Hold[30]:
IF(button.holdtime < 30)
HowLong_Phone = 0; //flag dial it
Else IF (button.holdtime > 30)
HowLong_Phone = 1; //flag go to another page
switch (button.input.channel)
case 21:
select
active(HowLong_Phone == 0):{SEND_STRING dvBiamp,"'DIAL 1 TIPHONENUM 136 ',cPhoneNumbers[1],$0A"} //Dial it
active(HowLong_Phone == 1):{Send_Command TP1A,'PAGE-Phone Book'} //Phone Book Page
case 22:
select
active(HowLong_Phone == 0):{SEND_STRING dvBiamp,"'DIAL 1 TIPHONENUM 136 ',cPhoneNumbers[2],$0A"} //Dial it
case 23:
select
active(HowLong_Phone == 0):{SEND_STRING dvBiamp,"'DIAL 1 TIPHONENUM 136 ',cPhoneNumbers[3],$0A"} //Dial it
case 24:
select
active(HowLong_Phone == 0):{SEND_STRING dvBiamp,"'DIAL 1 TIPHONENUM 136 ',cPhoneNumbers[4],$0A"} //Dial it
case 25:
select
active(HowLong_Phone == 0):{SEND_STRING dvBiamp,"'DIAL 1 TIPHONENUM 136 ',cPhoneNumbers[5],$0A"} //Dial it
case 26:
select
active(HowLong_Phone == 0):{SEND_STRING dvBiamp,"'DIAL 1 TIPHONENUM 136 ',cPhoneNumbers[6],$0A"} //Dial it
DEFAULT:{HowLong_Phone = 0;}
  • HedbergHedberg Posts: 671
    Best I can tell. button.holdtime is a long integer measured in msec. So, when I run the code that you include, the Hold[30}: code gets executed after 3.0 seconds and the value returned for buttton.holdtime is 2994.
    So, your flag variable in the code you wrote will always = 1.
    This is what I would suggest:
      push:
        HowLong_Phone = 0;	//initialize the flag everytime the button is pressed.
      hold[30]:  //this is when the button is held 3.0 seconds--it executes once only.
        HowLong_Phone = 1;
    	case 21:
    		Send_Command TP1A,'PAGE-Phone Book' //Phone Book Page
    	case 22:
           ///etc.
      release:
        if(!HowLong_Phone)  //this will be true if the button was released before 3.0 seconds
    	case 21:
    	case 22:
            //etc.
    perhaps you could simplify the hold event handler code if it always does the same thing when one of the buttons is held for more than 3.0 seconds.
    Also, the way that you have written your code suggests that you might be able to simplify the release: code
      release:
        stack_var integer nPhonePresetNbr
        if(!HowLong_Phone)
          nPhonePresetNbr = button.input.channel - 20
          SEND_STRING dvBiamp,"'DIAL 1 TIPHONENUM 136 ',cPhoneNumbers[nPhonePresetNbr],$0A"
  • avi_daveavi_dave Posts: 62
    much much much appreciated
  • NMarkRobertsNMarkRoberts Posts: 455
    Here is a version of your code that follows a number of well regarded coding practices:
    (Uncompiled and untested)
    define_constant
    nLongHoldTenths = 30
    nPhoneNumberBase = 20
      push:
        bLongHold = False
      hold[nLongHoldTenths]:
        bLongHold = True
        OpenPage('Phone Book')
      release:
        if (not bLongHold)
          SendBiampCommand(nBiampCodeDial,sPhoneNumbers[button.input.channel - nPhoneNumberBase])
    Your approach works fine although my instinct would be to do it like this:
      push:
        bLongHolding = True
        cancel_wait 'WaitLongHold' (* Just good practice *)
        wait nLongHoldTenths 'WaitLongHold'
          bLongHolding = False
      release:
        if (bLongHolding)
