NI-2000 POST sequence
I have an NI-2000 that WAS working just fine. We had to shut it down and move it. When we turned everything back on, I tripped over the power cord while the NI-2000 was going through its boot up process. Now it will not boot all. Instead, it just sits there with the Output light steady on. I can't get it to respond to anything. What in the world could I have done to it? Is it totally screwed?
  • NMarkRobertsNMarkRoberts Posts: 455
    (a) I don't think interrupting a boot would cause a problem in the master firmware although conceivably some persistent variable in the code was set wrongly which has caused it to become confused.
    (b) If you have just reinstalled a working system and now the output light is on constantly I'd guess one of the cables is wrongly installed and the code is desperately trying to get in touch with some box that isn't there. Is one of the serial transmit LEDs also on?
  • ryanwwryanww Posts: 196
    Also check that the compact flash card didn't come lose when you knocked the box.. I think that will cause it to be yellow as well when it can't find the card.
    Ryan
  • GSLogicGSLogic Posts: 562
    I have interrupted the bootup sequence many time without any issues. I check to make sure the cards didn't come loose.
