Streaming Audio to a Modero Viewpoint
Greetings,
Is there a way to stream audio to an MVP8400i? I only need audio, no video.
So if you keep uploading (stream) an MP3 file via FTP to the Modero, it might be able to play it? (this will probably NOT work, but why not try it
Well you can upload your MP3 files to disk of master, and then modify dinamycally through program url of ressource of a button in panel to load any MP3 avalaible from master disk
For info you can watch and listen Mp4 stream in wired VG Modero Series, I use to watch TV on touch panel here in france
Vinc
Even the intercom feature is panel to panel. No external audio source. You also can't send audio to an external (non-AMX) device.
I sure wish you could.
Unless someone knows something that I don't.
Sheldon Samuels
IPS Resources LLC
