Home AMX Control Products
TP Channel Code Convention
Greetings,
Does there exist a formal convention for channel codes on G3 panels? Beyond using the same channel numbers on the panel as the corresponding ir channels for transport, etc, I have heard of nothing as a standard.
"I didn't just fall off the turnip truck yesterday, it was quite a while ago!"
  • Re: TP Channel Code Convention
    Originally posted by TurnipTruck
    Greetings,
    I'm not sure on how current this is, but you can check tech note number 4.
    http://www.amxcorp.com/techsupport/PDNTechNote.asp?id=4
    It's a ittle inconsistent right now, but expect formalization of a lot of this with the Duet release.
