Variables
I am making a favorite channel structure. I tried originally making it like so:
Define Type
STRUCTURE fav_chnls_PRAMETERS
CHAR NAME [20]
INTEGER chanel
Define Variable
persistent fav_chnls_PRAMETERS FAV_CHNLS [48]
But whenever I try to load it, it would come up with errors like:
Ref Error ^Fav_chnls index to large
I have tried taking it and just making it a single variable by doing just "persistant Fav_chnls[48]" and just loading it in that, and it still had the errors on it. I then lowered it to 12, and the same, more errors. A 12 variable array is obviously not that large. a 48 is a big variable.
I am using a NI-2100 and I believe it has a 32meg card. I have used another processor with a 20 position structure using a 20 position name and a integer and it has no problem on a 2000. I don't see why I 2100 wouldn't be able to handle it.
Ryan
    Define Type
    CHAR NAME [20]
    INTEGER chanel
    Define Variable
    You didn?t post the offending code so I don?t know what you have tried and where you went wrong. Using the example STRUCT you posted, this is the syntax to use to load it:
    DEFINE_START
    FAV_CHNLS[1].Name = 'CNN'
    FAV_CHNLS[1].chanel = 202
    FAV_CHNLS[2].Name = 'C-SPAN'
    FAV_CHNLS[2].chanel = 350
    FAV_CHNLS[48].Name = 'NASA TV'
    FAV_CHNLS[48].chanel = 376
    HTH
  • ryanwwryanww Posts: 196
    Here is the code that I am using to load/retrieve the data.
    BUTTON_EVENT [dvTP_Controls,FAV_CHNLS_BTNS]
    PUSH:
    SELECT
    ACTIVE (!nEditChannel):
    SEND_COMMAND dvCable,"'XCH ',ITOA(FAV_CHNLS[BUTTON.INPUT.CHANNEL - 1000])"
    ACTIVE (nEditChannel):
    SEND_COMMAND dvTP_Nav,'AKEYP'
    WAIT_UNTIL (TP_DONE) 'Channel Edit'
    FAV_CHNLS[button.input.channel - 1000].CHANNEL = TP_NUM
    SEND_STRING 0,"FAV_CHNLS[BUTTON.INPUT.CHANNEL - 1000]"
    I know the recall of some is not correct as I was switching it around.. but the storing is the problem.
    I started loading some though NS, but I am just planning on loading them using a record flag from another button and then just loads a converted integer from the touch panel key pad.
    Aside from fixing the syntax errors you may want to rethink your logic. You are using BUTTON.INPUT.CHANNEL inside a WAIT_UNTIL and I?m guessing the value of the embedded object is not what you are expecting when the WAIT_UNTIL expires. You may want to consider assigning BUTTON.INPUT.CHANNEL to a variable before you pop up the keypad and then reference that variable after the WAIT_UNTIL expires.
  • This may be a problem by the WAIT_UNTIL(). The BUTTON.INPUT.CHANNEL may loose reference to the channel because of it, and the claculation will become 0-1000, which is too large as a reference to the structure array.
    Please edit the line
    to
    SEND_STRING 0," "FAV_CHNLS[',ITOA(BUTTON.INPUT.CHANNEL - 1000),']' "
    and check what it shows in terminal.
    Ahhhh.. I didn't even think about it.. I will go back tonight and try it again.. It is coming up with reference errors.
    But then again, I do remember just trying it using a fixed position number like 12 and I think it still came up with the error message. I will try it again..
    and I knew the debug line was off.. just too busy doing other things..
    Ryan
    So this should work.. or am I an idiot.. lol.. <don't answer that>
    PUSH:
    LOCAL_VAR INTEGER CURRENT_CHNL
    CURRENT_CHNL = BUTTON.INPUT.CHANNEL - 1000
    SELECT
    FAV_CHNLS[CURRENT_CHNL] = TP_NUM
    SEND_STRING 0,"'FAV_CHNLS'"
    SEND_STRING 0,"'CHANNEL SENT',ITOA (FAV_CHNLS[CURRENT_CHNL])"
    I could also do a get last on the channel structure of the buttons I suppose.. but either way..
    I assume dvTP_Controls is an array of touch panels. If that?s the case and if someone presses one of the FAV_CHNLS_BTNS from a different TP before the WAIT_UNTIL expires then your CURRENT_CHNL variable will change. It?s probably an unlikely scenario but you may want to keep it in mind and possibly make some adjustments.
    You need to change the line:
    To:
    SEND_COMMAND dvCable,"'XCH ',ITOA(FAV_CHNLS[BUTTON.INPUT.CHANNEL - 1000]. chanel)"
    Or
    SEND_COMMAND dvCable,"'XCH ',ITOA(FAV_CHNLS[CURRENT_CHNL]. chanel)"
    The same goes for the SEND_STRING 0 statements.
    You also need to change the line:
    TO:
    FAV_CHNLS[CURRENT_CHNL].chanel = TP_NUM
    I prefer using GET_LAST() over BUTTON.INPUT.CHANNEL-(some offset) because it?s more flexible. But just because I would do it that way doesn?t make your way any less correct.
    Happy channel changing.
    Sorry, forgot to mention.. I took out the structure.. It was too much to deal with names.. and I wasn't going to use it as far as button text because all of them are icons.. So it would just be FAV_CHANLS[#].. COrrect?
    Yup, you got it. :)
    I think I found the reason it kept kicking back the error:
    oops...
    but hey, I got it now. Thanks for all your help as always,
    Ryan
