Upload of .irl file to NI-3100 fails
I have a home with three controllers (one each of 3100, 900, and 700) in it that's about to go live and everything seems ok, except I can't get one IR file to upload to the NI-3100. The file is one that I've used before in other projects and it works just fine. In fact, it will upload to the 900 with nary a complaint. The error that I get is not terribly informative:
Item transfer has not started in 25 secs. Cancelling Item transfer.
The device declaration is:
dvCable_Loft = 5001:9:2
I also tried 5001:10:2 and 5001:11:2, and 5001:9:0. I tried deleting the mapping and re-establishing it, and then completely removing the file from the project and then adding it back in. I thought it might be a problem with the security settings, so I turned all of that off from the controller's web interface and unchecked the "Authentication required" checkbox in communication settings. None of that helped.
I'm sort of at a loss now. Any ideas? Thanks in advance.
!!! On your own risk !!!
From terminal, do a CLEAN DISK<enter>, let it finish, reboot the master and reload your project to the master.
It looks like you're using master to master. Have you tried connecting directly to that master's ip address?
Did you go to the worktree in Netlinx Studio and check the 'System Properties' for the system to make sure that the System ID is correct and that it matches the NI-3100's setting? Did you also make sure to change the system # on the NI-3100 to System #2. If your System ID # is set wrong in the properties or on the controller, then when you try to transfer the file it will look like it's trying to communicate, but then it times out and gives you the error message you mentioned: "Item transfer has not started in 25 secs. Cancelling Item transfer."
Hope this helps.
--John
--John
I'm trying to transfer the file directly to the controller in question from NetLinx Studio, using the File Transfer dialog.
I set the system number through the web interface, and it seems to be displaying correctly in NetLinx Studio
From the web interface, it still looks like it's set at system 2. Maybe a factory reset or something is in order?
Do other files transfer o.k. to that Master through studio?
I could be mistaken about 'clean disk' resetting everything. I thought I remembered having to reset the port # for NS Studio Access, but I wasn't sure about the system #. Always good to reboot the master controller after you do those kind of operations anyway though.
--John
Maybe it's time for you to go get the box out of the loft, put it on your desk, attach to it directly using a crossover cable, strip it down to bare metal, give it system number 1, and see what happens.
I have two controllers here on my desk that I'm using to test stuff for this project and I was fiddling with them to try and make this work when I noticed an odd thing.
If you look at these images:
System tree on the NI-900
System tree on the NI-3100
you'll see that the NI-900 has a 5001 entry for the controller, while the NI-3100 does not. In the NI-3100's system tree, the only entry labeled "NI-3100" has an address of 32002. I don't know if this is significant or not, but it seems like it might be. Is my 3100 horribly misconfigured or something?
I've been using this 3100 to test code on for a couple months now, and it's never misbehaved before. But maybe that's because I never needed to use anything but system ID 0 for device declarations before now.
Thankfully, this house isn't live yet. I'm currently just testing all this stuff on my controller here at my office. It's possible that none of this will be an issue when we actually get up there to load code. In my post above, I mention a thing that I noticed earlier that may be the root of my problems here.
The addressing thing was the problem. I re-addressed my NI-3100 from 32002 to 5001 and everything uploaded just fine. I don't know how that address got changed (to be honest, I didn't know it COULD be changed), but everything appears to be working now. Thanks for all the responses, everyone. I really appreciate the help.
That's the 2nd thing you do when installing a new one, immediately after assigning an IP address and before setting the date and time.
Maybe your attempts to do a factory reset also reset the device number.
some firmware upgrades will change the device address.
Again, glad to hear you were able to get it figured out.
--John
The 32000 range of addresses is reserved for runtime generated devices. Most likely, it simply lost it's address (I've had this happen to me only twice since I have started using NetLinx, so it's very rare, but not unheard of), and the system saw it was there and assigned it in that range. If it were me, I wouldn't worry about it unless it starts happening on a regular basis; most likely, it was the firmware update, as has been suggested.
