Home AMX Control Products
TPI4 Native Resolution
Hi all,
We have a bunch of TPI4's controlling LCD wide screens.
The native resolution for the LCD's are 1440 x 900. The TPI4's resolution max is 1280 x 1024.
We have scaled the images so that when they are display on the lcd they are in the correct aspect ratio. The problem is that the LCD's are "soft" due to the scaling from 1280x1024 to 1440x900.
I was wondering if any one knows if it is possible to change the native resolution of the TPI4's?
Regards
Craig
  • Unfortunately not, as each possible resolution requires matching settings in the design software... The resolutions you can get by cycling through on the front panel are the only ones that are supported.
    - Chip
