NI-4100 locks up when panel goes online
Hi. I've searched around here for clues as to what might be going on, but I've come up empty. Basically, I've got a system with 13 panels, and I've got modules for AudioReQuest, VideoReQuest, Polk Audio XM, Vantage Lighting, Security Cameras, Aprilaire HVAC, etc. I'm running an NI-4100 with v.3.21.354, and the latest device firmware too. I was running a slightly older version when this started happening and upgraded hoping that would fix it - it didn't.
Anyway, I can consistently reproduce the problem... I have 3 MVP-8400's and everything works fine if I pull the batteries out of one of them (preventing it from going online) before the controller boots up. Here's how things look before I put the batteries into the last MVP:
>show mem
Volatile Free   :  1590336 (largest free block in bytes)
NonVolatile Free:   930360 (bytes free)
Disk Free       :120852480 (bytes of free space)
Duet Memory Free :   975708 (bytes)
 Partition 1 -    975708 (bytes)
 Partition 2 - <UNKNOWN>
'Volatile Free' is my problem - it quickly goes to zero (or close to zero) when the last MVP is allowed to come online. Does the amount of 'Volatile Free' seem unusually low for a system of this size? Doesn't the NI-X100 series have twice the RAM of the older units? Anyway, here's what happens when the last panel comes online:
>show mem
Volatile Free   :    18336 (largest free block in bytes)
As a result, the controller completely locks up, since it basically has no available 'Volatile Free'. When the last panel starts to come online, here's what the notifications show:
Line   3904 :: Command To [10506:1:1]-[LEVON] - 09:49:54
Line   3905 :: Command To [10506:1:1]-[RXON] - 09:49:54
Line   3906 :: Command To [10506:4:1]-[LEVON] - 09:49:54
Line   3907 :: Command To [10506:4:1]-[RXON] - 09:49:54
Line   3908 :: Feedback:On [10506:4:1] - Channel 2  - 09:49:54
Line   3909 :: Output Channel:On - From [10506:4:1] - Channel 2  - 09:49:54
Line   3910 :: Feedback:On [10506:4:1] - Channel 24  - 09:49:54
Line   3911 :: Output Channel:On - From [10506:4:1] - Channel 24  - 09:49:54
Line   3912 :: Feedback:On [10506:4:1] - Channel 44  - 09:49:54
Line   3913 :: Output Channel:On - From [10506:4:1] - Channel 44  - 09:49:54
Line   3914 :: Feedback:On [10506:4:1] - Channel 147  - 09:49:54
Line   3915 :: Output Channel:On - From [10506:4:1] - Channel 147  - 09:49:54
Line   3916 :: Feedback:On [10506:4:1] - Channel 151  - 09:49:54
Line   3917 :: Output Channel:On - From [10506:4:1] - Channel 151  - 09:49:54
Line   3918 :: Feedback:On [10506:4:1] - Channel 158  - 09:49:54
Line   3919 :: Output Channel:On - From [10506:4:1] - Channel 158  - 09:49:54
Line   3920 :: Output Channel Count [10506:1:1] - 622 - 09:49:54
Line   3921 :: Level Count [10506:1:1] - 268 - 09:49:54
Line   3922 :: Level Size [10506:1:1] - Level 1 Supported Types=BYTE,CHAR,INTEGER,SINTEGER,ULONG,LONG,FLOAT,DOUBLE,Unknown - 09:49:54
Line   3923 :: String Size [10506:1:1] 199 byte(s) Type: 8 bit - 09:49:54
Line   3924 :: Command Size [10506:1:1] 199 byte(s) Type: 8 bit - 09:49:54
Line   3925 :: Output Channel Count [10506:2:1] - 622 - 09:49:54
Line   3926 :: Level Count [10506:2:1] - 268 - 09:49:54
Line   3927 :: String Size [10506:2:1] 199 byte(s) Type: 8 bit - 09:49:54
Line   3928 :: Command Size [10506:2:1] 199 byte(s) Type: 8 bit - 09:49:54
Line   3929 :: Output Channel Count [10506:3:1] - 622 - 09:49:54
Line   3930 :: Level Count [10506:3:1] - 268 - 09:49:54
Line   3931 :: String Size [10506:3:1] 199 byte(s) Type: 8 bit - 09:49:54
Line   3932 :: Command Size [10506:3:1] 199 byte(s) Type: 8 bit - 09:49:54
Line   3933 :: Output Channel Count [10506:4:1] - 622 - 09:49:54
Line   3934 :: Level Count [10506:4:1] - 268 - 09:49:54
Line   3935 :: Level Size [10506:4:1] - Level 266 Supported Types=BYTE,CHAR,INTEGER,SINTEGER,ULONG,LONG,FLOAT,DOUBLE,Unknown - 09:49:54
Line   3936 :: Level Size [10506:4:1] - Level 267 Supported Types=BYTE,CHAR,INTEGER,SINTEGER,ULONG,LONG,FLOAT,DOUBLE,Unknown - 09:49:54
Line   3937 :: Level Size [10506:4:1] - Level 268 Supported Types=BYTE,CHAR,INTEGER,SINTEGER,ULONG,LONG,FLOAT,DOUBLE,Unknown - 09:49:54
Line   3938 :: String Size [10506:4:1] 199 byte(s) Type: 8 bit - 09:49:54
Line   3939 :: Command Size [10506:4:1] 199 byte(s) Type: 8 bit - 09:49:54
Line   3940 :: Output Channel Count [10506:5:1] - 622 - 09:49:54
Line   3941 :: Level Count [10506:5:1] - 268 - 09:49:54
Line   3942 :: String Size [10506:5:1] 199 byte(s) Type: 8 bit - 09:49:54
Line   3943 :: Command Size [10506:5:1] 199 byte(s) Type: 8 bit - 09:49:54
Line   3944 :: Output Channel Count [10506:6:1] - 622 - 09:49:54
Line   3945 :: Level Count [10506:6:1] - 268 - 09:49:54
Line   3946 :: String Size [10506:6:1] 199 byte(s) Type: 8 bit - 09:49:54
Line   3947 :: Command Size [10506:6:1] 199 byte(s) Type: 8 bit - 09:49:54
Line   3948 :: Output Channel Count [10506:7:1] - 622 - 09:49:54
Line   3949 :: Level Count [10506:7:1] - 268 - 09:49:54
Line   3950 :: String Size [10506:7:1] 199 byte(s) Type: 8 bit - 09:49:54
Line   3951 :: Command Size [10506:7:1] 199 byte(s) Type: 8 bit - 09:49:54
Line   3952 :: Output Channel Count [10506:8:1] - 622 - 09:49:54
Line   3953 :: Level Count [10506:8:1] - 268 - 09:49:54
Line   3954 :: String Size [10506:8:1] 199 byte(s) Type: 8 bit - 09:49:54
Line   3955 :: Command Size [10506:8:1] 199 byte(s) Type: 8 bit - 09:49:54
Line   3956 :: Output Channel Count [10506:9:1] - 622 - 09:49:54
Line   3957 :: Level Count [10506:9:1] - 268 - 09:49:54
Line   3958 :: String Size [10506:9:1] 199 byte(s) Type: 8 bit - 09:49:54
Line   3959 :: Command Size [10506:9:1] 199 byte(s) Type: 8 bit - 09:49:54
Line   3960 :: Output Channel Count [10506:10:1] - 622 - 09:49:54
Line   3961 :: Level Count [10506:10:1] - 268 - 09:49:54
Line   3962 :: String Size [10506:10:1] 199 byte(s) Type: 8 bit - 09:49:54
Line   3963 :: Command Size [10506:10:1] 199 byte(s) Type: 8 bit - 09:49:54
Line   3964 :: Output Channel Count [10506:11:1] - 622 - 09:49:54
Line   3965 :: Level Count [10506:11:1] - 268 - 09:49:54
Line   3966 :: String Size [10506:11:1] 199 byte(s) Type: 8 bit - 09:49:54
Line   3967 :: Command Size [10506:11:1] 199 byte(s) Type: 8 bit - 09:49:54
Line   3968 :: Output Channel Count [10506:12:1] - 622 - 09:49:54
Line   3969 :: Level Count [10506:12:1] - 268 - 09:49:54
Line   3970 :: String Size [10506:12:1] 199 byte(s) Type: 8 bit - 09:49:54
Line   3971 :: Command Size [10506:12:1] 199 byte(s) Type: 8 bit - 09:49:54
Line   3972 :: Output Channel Count [10506:13:1] - 622 - 09:49:54
Line   3973 :: Level Count [10506:13:1] - 268 - 09:49:54
Line   3974 :: String Size [10506:13:1] 199 byte(s) Type: 8 bit - 09:49:54
Line   3975 :: Command Size [10506:13:1] 199 byte(s) Type: 8 bit - 09:49:54
Line   3976 :: Output Channel Count [10506:14:1] - 622 - 09:49:54
Line   3977 :: Level Count [10506:14:1] - 268 - 09:49:54
Line   3978 :: String Size [10506:14:1] 199 byte(s) Type: 8 bit - 09:49:54
Line   3979 :: Command Size [10506:14:1] 199 byte(s) Type: 8 bit - 09:49:54
Line   3980 :: Output Channel Count [10506:15:1] - 622 - 09:49:54
Line   3981 :: Level Count [10506:15:1] - 268 - 09:49:54
Line   3982 :: Level Size [10506:15:1] - Level 1 Supported Types=BYTE,CHAR,INTEGER,SINTEGER,ULONG,LONG,FLOAT,DOUBLE,Unknown - 09:49:54
Line   3983 :: String Size [10506:15:1] 199 byte(s) Type: 8 bit - 09:49:54
Line   3984 :: Command Size [10506:15:1] 199 byte(s) Type: 8 bit - 09:49:54
Line   3985 :: Output Channel Count [10506:16:1] - 622 - 09:49:54
Line   3986 :: Level Count [10506:16:1] - 268 - 09:49:54
Line   3987 :: String Size [10506:16:1] 199 byte(s) Type: 8 bit - 09:49:54
Line   3988 :: Command Size [10506:16:1] 199 byte(s) Type: 8 bit - 09:49:54
Line   3989 :: Output Channel Count [10506:17:1] - 622 - 09:49:54
Line   3990 :: Level Count [10506:17:1] - 268 - 09:49:54
Line   3991 :: String Size [10506:17:1] 199 byte(s) Type: 8 bit - 09:49:54
Line   3992 :: Command Size [10506:17:1] 199 byte(s) Type: 8 bit - 09:49:54
Line   3993 :: Output Channel Count [10506:18:1] - 622 - 09:49:54
Line   3994 :: Level Count [10506:18:1] - 268 - 09:49:54
Line   3995 :: String Size [10506:18:1] 199 byte(s) Type: 8 bit - 09:49:54
Line   3996 :: Command Size [10506:18:1] 199 byte(s) Type: 8 bit - 09:49:54
Line   3997 :: Output Channel Count [10506:19:1] - 622 - 09:49:54
Line   3998 :: Level Count [10506:19:1] - 268 - 09:49:54
Line   3999 :: String Size [10506:19:1] 199 byte(s) Type: 8 bit - 09:49:54
Line   4000 :: Command Size [10506:19:1] 199 byte(s) Type: 8 bit - 09:49:54
Line   4001 :: Output Channel Count [10506:20:1] - 622 - 09:49:54
Line   4002 :: Level Count [10506:20:1] - 268 - 09:49:54
Line   4003 :: String Size [10506:20:1] 199 byte(s) Type: 8 bit - 09:49:54
Line   4004 :: Command Size [10506:20:1] 199 byte(s) Type: 8 bit - 09:49:54
Line   4005 :: Output Channel Count [10506:21:1] - 622 - 09:49:54
Line   4006 :: Level Count [10506:21:1] - 268 - 09:49:54
Line   4007 :: String Size [10506:21:1] 199 byte(s) Type: 8 bit - 09:49:54
Line   4008 :: Command Size [10506:21:1] 199 byte(s) Type: 8 bit - 09:49:54
Line   4009 :: Output Channel Count [10506:22:1] - 622 - 09:49:54
Line   4010 :: Level Count [10506:22:1] - 268 - 09:49:54
Line   4011 :: String Size [10506:22:1] 199 byte(s) Type: 8 bit - 09:49:54
Line   4012 :: Command Size [10506:22:1] 199 byte(s) Type: 8 bit - 09:49:54
Line   4013 :: Output Channel Count [10506:23:1] - 622 - 09:49:54
Line   4014 :: Level Count [10506:23:1] - 268 - 09:49:54
Line   4015 :: String Size [10506:23:1] 199 byte(s) Type: 8 bit - 09:49:54
Line   4016 :: Command Size [10506:23:1] 199 byte(s) Type: 8 bit - 09:49:54
Line   4017 :: Output Channel Count [10506:24:1] - 622 - 09:49:54
Line   4018 :: Level Count [10506:24:1] - 268 - 09:49:54
Line   4019 :: String Size [10506:24:1] 199 byte(s) Type: 8 bit - 09:49:54
Line   4020 :: Command Size [10506:24:1] 199 byte(s) Type: 8 bit - 09:49:54
Line   4021 :: Output Channel Count [10506:25:1] - 622 - 09:49:54
Line   4022 :: Level Count [10506:25:1] - 268 - 09:49:54
Line   4023 :: String Size [10506:25:1] 199 byte(s) Type: 8 bit - 09:49:54
Line   4024 :: Command Size [10506:25:1] 199 byte(s) Type: 8 bit - 09:49:54
Line   4025 :: Output Channel Count [10506:26:1] - 622 - 09:49:54
Line   4026 :: Level Count [10506:26:1] - 268 - 09:49:54
Line   4027 :: String Size [10506:26:1] 199 byte(s) Type: 8 bit - 09:49:54
Line   4028 :: Command Size [10506:26:1] 199 byte(s) Type: 8 bit - 09:49:54
Line   4029 :: Output Channel Count [10506:27:1] - 622 - 09:49:54
Line   4030 :: Level Count [10506:27:1] - 268 - 09:49:54
Line   4031 :: String Size [10506:27:1] 199 byte(s) Type: 8 bit - 09:49:54
Line   4032 :: Command Size [10506:27:1] 199 byte(s) Type: 8 bit - 09:49:54
Line   4033 :: Output Channel Count [10506:28:1] - 622 - 09:49:54
Line   4034 :: Level Count [10506:28:1] - 268 - 09:49:54
Line   4035 :: String Size [10506:28:1] 199 byte(s) Type: 8 bit - 09:49:54
Line   4036 :: Command Size [10506:28:1] 199 byte(s) Type: 8 bit - 09:49:54
Line   4037 :: Output Channel Count [10506:29:1] - 622 - 09:49:54
Line   4038 :: Level Count [10506:29:1] - 268 - 09:49:54
Line   4039 :: String Size [10506:29:1] 199 byte(s) Type: 8 bit - 09:49:54
Line   4040 :: Command Size [10506:29:1] 199 byte(s) Type: 8 bit - 09:49:54
Line   4041 :: Output Channel Count [10506:30:1] - 622 - 09:49:54
Line   4042 :: Level Count [10506:30:1] - 268 - 09:49:54
Line   4043 :: String Size [10506:30:1] 199 byte(s) Type: 8 bit - 09:49:54
Line   4044 :: Command Size [10506:30:1] 199 byte(s) Type: 8 bit - 09:49:54
Line   4045 :: Output Channel Count [10506:31:1] - 622 - 09:49:54
Line   4046 :: Level Count [10506:31:1] - 268 - 09:49:54
Line   4047 :: String Size [10506:31:1] 199 byte(s) Type: 8 bit - 09:49:54
Line   4048 :: Command Size [10506:31:1] 199 byte(s) Type: 8 bit - 09:49:54
Line   4049 :: Output Channel Count [10506:32:1] - 622 - 09:49:54
Line   4050 :: Level Count [10506:32:1] - 268 - 09:49:54
Line   4051 :: String Size [10506:32:1] 199 byte(s) Type: 8 bit - 09:49:54
Line   4052 :: Command Size [10506:32:1] 199 byte(s) Type: 8 bit - 09:49:54
Line   4053 :: Output Channel Count [10506:33:1] - 622 - 09:49:54
Line   4054 :: Level Count [10506:33:1] - 268 - 09:49:54
Line   4055 :: String Size [10506:33:1] 199 byte(s) Type: 8 bit - 09:49:54
Line   4056 :: Command Size [10506:33:1] 199 byte(s) Type: 8 bit - 09:49:54
Line   4057 :: Output Channel Count [10506:34:1] - 622 - 09:49:54
Line   4058 :: Level Count [10506:34:1] - 268 - 09:49:54
Line   4059 :: String Size [10506:34:1] 199 byte(s) Type: 8 bit - 09:49:54
Line   4060 :: Command Size [10506:34:1] 199 byte(s) Type: 8 bit - 09:49:54
Line   4061 :: Output Channel Count [10506:35:1] - 622 - 09:49:54
Does anybody see anything strange here that I'm missing? Any kind of hint would be *much* appreciated... I'm at a complete loss as to what's going on here. I've been 'updating' my panels to a new design that's quite a bit different, and somehow it seems to be related. If I leave the 'old' design on the MVP and let it boot up, 'Volatile Free' drops by about 1.1MB - not enough to bring the server down. The 'new' design must drop the RAM by more than that. I also tried to 'remove user pages' from the MVP and let it boot - and it only dropped the RAM by 35KB! Seems to be related to the panel file somehow. I have also been able to bring the system down with a CV-7 - so it's not specific to the MVP's (although I did do a 'save as' panel type from the MVP panel file). I've checked my online events and there's nothing I see that would eat up the RAM like that. Maybe the system can handle 12 panels 'as is', but the 13th is too much?
Thanks in advance for your comments and suggestions.
Regards,
Mark
  • jjamesjjames Posts: 2,908
    Out of curiosity - do you have a ONLINE / DATA_EVENT for your TPs? If so, what is it? I'm certainly not the one that'll be able to provide any type of hint or answer, but I'm curious to look at this (if you have one.)
  • Yes - I've got a couple...
    Polk XM Radio (Port 14):
    DATA_EVENT[dvTP_XM]
        ONLINE:
    	SEND_COMMAND vdvXM,"'RADIOID?'"
    	SEND_COMMAND vdvXM,"'SIGNAL_STRENGTH?'"
    	SEND_COMMAND dvTP_XM,"'!T',nTextButtons[TXT_STATION]"
    	SEND_COMMAND dvTP_XM,"'!T',nTextButtons[TXT_ARTIST]"
    	SEND_COMMAND dvTP_XM,"'!T',nTextButtons[TXT_GENRE]"
    	SEND_COMMAND dvTP_XM,"'!T',nTextButtons[TXT_RADIOID]"
    	SEND_COMMAND dvTP_XM,"'!T',nTextButtons[TXT_SONG]"
    	SEND_COMMAND dvTP_XM,"'!T',nTextButtons[TXT_CHANNEL]"
    Here's another (Port 10):
    DATA_EVENT[dvTP_UTILITY]
       ONLINE:
            STACK_VAR INTEGER i
            i = GET_LAST(dvTP_UTILITY)
            // Turn page tracking on
            SEND_COMMAND dvTP_UTILITY[i], 'TPAGEON'
            SEND_COMMAND dvTP_UTILITY[i], "'!T',5,'SYSTEM MESSAGE'"
            SEND_COMMAND dvTP_UTILITY[i], "'!T',6,' ',DAY,' ',DATE,' ',TIME"
            SEND_COMMAND dvTP_UTILITY[i], "'!T',7,' '"
            SEND_COMMAND dvTP_UTILITY[i], "'!T',8,'Device ',sPANEL_INFO[i].DESCRIPTION,' is online '"
            SEND_COMMAND dvTP_UTILITY[i], "'!T',9,' '"
            SEND_COMMAND dvTP_UTILITY[i], "'PPON-DialogBox_Centered'"
            SEND_COMMAND dvTP_UTILITY[i], ("'CLOCK ',DATE,' ',TIME")
    	SEND_STRING 0,"DATE, ' ', TIME, ' - Touch Panel ', sPANEL_INFO[i].DESCRIPTION, ' went online.'"
    I didn't notice anything here that would eat into my RAM, but I may have gotten glossy eyed looking at it for so long.
    Thanks for your help!
    Mark
    Your notifications capture shows references up to (maybe there are more) port 34 on the panel. Are you really using that many ports? That is most likely the problem - every port defined causes the master to allocate resources to control all the available channels, levels, etc ... for every port. Your 13 panels are now like 442 because they reference port 34.
    More than likely, some port numbers were actually skipped and are not being used at all. However, resources are still allocated for them. Try it - define a panel as using port one, and port 10 on a master. Even though the panel has no references to ports 2-9, your online tree will show all ten ports. Memory and events are assigned to each one, whether you are using them or not.
    I find it difficult to believe your panel design really needs 34 (or more) ports. Consolidate them and get rid of the in-between, unused port numbers. If it really does need that many ports, you may need to think of another way to do it - like sharing ports for some devices, and using a virtual with dynamic combines. But you got to get rid of all those ports when you have so many panels.
  • Line   3935 :: Level Size [10506:4:1] - Level 266 Supported Types=BYTE,CHAR,INTEGER,SINTEGER,ULONG,LONG,FLOAT,DOUBLE,Unknown - 09:49:54
    I'm thinking the problem is something to do with this, similar to what DHawthorne said about ports but with levels. If you have levels it sets up stuff for all the intermediate levels. Plus I forget off the top of my head but it seems like those are over the max number of levels you can have. I'm guessing 256 is the max. If you're constantly updating a level, it probably doesn't know what the existing level is so it keep sending data out to that level on the tp all the time.
    Also noticed you're sending a text string out to the panel with the date and time. You can use the panels system ports as that will sync up with the master's time automatically. Unless you're doing something like someone else did where the user can change the timezone of the panel to match his different branch offices.
    Also I noticed you were sending o
  • Dave,
    You're the man! You were right - I do have quite a few ports defined both in my code and on the panels. My code definitions basically look like this:
    // TP11 - FAMILY ROOM (MVP-8400)
        arqTP11 			= 10506:1:1	  // AudioReQuest
        vrqTP11			= 10506:2:1       // VideoReQuest
        hvacTP11                 	= 10506:3:1 	  // Heating
        adaTP11                 	= 10506:4:1	  // ADA Suite 16
        azcTP11			= 10506:5:1	  // Audio Zone Control
        avTP11			= 10506:6:1	  // Audio/Video Equipment
        radTP11	          	= 10506:7:1	  // Radionics Security
        scTP11			= 10506:8:1	  // Security Cameras
        kalTP11			= 10506:9:1	  // Kalatel Security Camera DVR
        utilTP11                  	= 10506:10:1      // Utility/Touchpanel Routines
        atvTP11			= 10506:11:1	  // Apple TV
        dtvTP11               	= 10506:12:1	  // For Rack DVR (HR20-700)
        xmTP11			= 10506:14:1	  // Polk Audio XRt12
        xmdTP11			= 10506:15:1	  // Polk Audio XRt12 - Direct Channel Input
        dvdTP11                 	= 10506:16:1
        vzcTP11			= 10506:17:1	  // Video Zone Control
        weatherTP11			= 10506:23:1      // RSS Weather Feed
        c1TP11			= 10506:26:1	  // Parasound C1 (Home Theater)
        c2TP11			= 10506:28:1	  // Parasound C2 (Living Room)
        hkTP11			= 10506:29:1	  // Harman Kardon DPR-1001
        apTP11			= 10506:30:1	  // AutoPatch 1YDM Component Video & Digital Audio Switch
        tv1TP11			= 10506:32:1	  // Samsung DLP TV in Living Room
        tv2TP11			= 10506:34:1	  // Samsung DLP TV in Family Room
        tv3TP11			= 10506:36:1	  // Samsung DLP TV in Exercise Room
        tv4TP11			= 10506:38:1	  // Samsung DLP TV in Downstairs Office
    On the panel side, I incorporated the nicely done weather module that was posted on the board (VAV!) and it had a reference to port 1 on the panel file that was used for sunrise and sunset. Since I knew I used port 1 for the AudioReQuest, I 'temporarily' set it to 100 - thinking I would set it to a port number out of the way for now and circle back to it later. Unfortunately, by setting it to 100 it was allocating memory for ports 1-100 as you described. My controller could handle six panels with 100 ports, but the seventh would cause the out of memory error. Thank you very much for your help! I am now back up to 21.8MB available 'Volatile Free' instead of just 1.6MB!
    While we're on the subject of maximizing memory usage and minimizing port usage, I thought I might as a couple more questions. Does the controller allocate the memory based on definitions in code, or by the maximum port number that is defined in the actual TP4 file? Based on my experience it seems to be the latter, but I thought I would just check. Is there any way to control the 'output channel count' or the 'level count' that's displayed in the notifications log? As far as consolidating ports goes, I could roll up my four TV's (for example) into one port and have channel codes 1-70 reference IR codes for TV1, 71-140 reference TV2, etc. If I remember right, there's a limit on the array size too - isn't there? Any suggestions on how to best consolidate ports, or to maximize the number of channel codes per port?
    As far as having a need for 34 ports, I probably need more like 24 or so (at the moment). I'm trying to make all of my panel files identical, based on panel type (CV-7, MVP-8400, CV-15 & CV-17). In code, I check to see what panel is requesting a certain menu, etc. and then redirect it appropriately. It's alot easier to modify one panel file for all CV-7's than to have a panel file for each location. I've also setup my system to allow users to 'select' any audio or video zone and to control everything there - hence the need to control basically everything from each panel.
    You were right about my having unused in-between ports - I was trying to leave a little space between them so I could logically expand (and insert as necessary) in the future. I had no idea it was eating up so much RAM. I'll focus on consolidating ports and being a little careful about expanding my usage of them in the future.
    Thank You!
    Mark
    Wow - 24 ports still seem like a lot. Are you sure you couldn't get it down to less than 10? Glad the problem was solved, now I'd work on code & panel efficiency. ;)
    The AMX AutoPatch module uses 10 TP ports all by it self, of course that's one reason I don't use it.
    In my office system I'm quite happily running 30 ports but only on 2 full time TPs.
    Sheesh! That's crazy! I personally try not to use modules. It keeps down on ports, and I can control how I want data to flow in and out, etc. Anyway, I guess we're getting off track.
    I now remember Dave mentioning this before. I think there was a thread about it to be honest, but I'm not entirely sure. Regardless, let us know how you fair on the rest of the job.
  • Alex,
    Thanks for your comment. I believe those levels in the notifications are accurate - the port numbers noted match with what I'm using. Maybe I should use something below 256, but it seems to work OK. I put in a global variable (via a structure) that keeps track of whether or not the level is in the process of being changed, and then set it back to 'no' after a wait. I know what you're talking about regarding the constant updating of levels, but this seems to work. I don't know why it shows the various types supported, or how that can be controlled. You're right about the date and time - I should probably use the panel's system ports instead.
    Mark
    ? Level range: 1 - 600
    But those are virtual interfaces, not panel ports, no? It's not so bad if they only appear once and aren't being multiplied by every panel. I can't imagine an automated system where you would want to do the switching on a panel; it should all be behind the scenes when you select a source.
    Another note, on the conservation of ports, is there is rarely any real need to have separate panel ports for IR controlled devices. I throw them all on the same port, and use a SWITCH...CASE or SELECT...ACTIVE based on the device in use to send the commands to the correct IR device.
    Nope! This is the new Duet Module:
    // 10001 == the Touch Panel device
    dvTPSliders      = 10001:1:0   /// The sliders, for gain and volume level control
    dvTPInput 	 = 10001:1:0   /// Port for all input buttons
    dvTPOutput 	 = 10001:2:0   /// Port for all output buttons
    dvTPLevel 	 = 10001:3:0   /// Port for all level (VM) buttons
    dvTPVolume 	 = 10001:4:0   /// Port for Volume function buttons... first 8 are output buttons
    dvTPGain	 = 10001:5:0   /// Port for Gain function buttons... first 8 are input buttons
    dvTPAdvanced     = 10001:8:0   /// Port for Advanced buttons (i.e. 'reinitialize' 'load status' etc)
    dvTPStatus       = 10001:10:0  /// Port for status (i.e. Online and Initialized) LEDs
    dvTP             = 10001:1:0  // Touch Panel
    When I first looked at the module as a usable option I looked at this and was completely dumb founded. It appears they couldn't figure out how to re-use numbers 1-10 so they just made a different port instead.
    I don't believe this was written by an AMX staffer but some one from AP.
  • Dave,
    Regarding the conservation of ports, is there any limit to the number of command codes that can be used on one port? Is there a maximum command code? Do you generally have different arrays for each IR device, or do you have one large array that lumps them all together? The way I see it, you can either lump them together and do a SWITCH...CASE or you can have multiple button events referencing the different arrays (which references each IR device separately) - right? Which do you prefer?
    Thanks again for your help.
    Mark
  • AMXJeffAMXJeff Posts: 450
    Qty or Ports
    Do not be pernoid be the use of many ports. Alot of programmers use a single TP port for single device control. So you can have up to 100 ports in use by a TP. I would suggest you comment out your code until you find out what is causing the lock up. I would start by commenting out all your online events for your TPs. You may also want to do a debounce on your online events, if you have a lot of panels that come on at the same time you code could execute tons of time. I would suggest a 2 second debounce time, with a cancel wait right before
    the wait 20.
    As far as your question about qty of send commands to a netlinx device. The G4 touch panels pretty much can take the commands as fast as possible. But if I am sending alot of them I tend to queue them and pace them to the TP. Keep in mind that all programmers need to learn to manager resources and processing time on any platform. That is the main differance between an ok programmer and a great programmer.
    DATA_EVENT[dvTPArray]
    	ONLINE:
    		CANCEL_WAIT 'TP COMING ONLINE'
    		WAIT 20 'TP COMING ONLINE'
    			// DO INIT STUFF NOW.
    the wait 20.
    Jeff, he already confirmed it was the number of ports. It matters a lot on big systems with a lot of panels; I know this from bitter experience.
    I have had very large project with hugh numbers of panels with tons of ports. I have never seen this issue. Which does not mean it does not exist, was this prior to the controllers coming with there device manager buffers and thresholds set high?
    It's going to vary with the size of the rest of your code. In many cases, you can probably get away with it. IN some you are not.
    I guess they don't cover this in all the training courses, because when I went, the instructor was very adamant about it: don't skip port numbers because of the resource drain. It's a real issue, and it doesn't rear it's head under all circumstances, but that doesn't make it any less there.
