Nion N3 Feedback Gibberish
We are programming a Peavey Media Matrix (Nion N3) using Pasha. When we send commands, we get back random gibberish. We have checked to make sure both the AMX and the Nion are set to RS485 communications and we have make sure all items in the Nion were IDed properly. We have checked to make sure the cabling was correct. We have used our code before on a previous job with the Nion and it worked fine. Does anyone have any idea what else may be causing the erroneous feedback?
    Sounds like a baud rate problem. Either you are setting the rate wrong, or setting it at the wrong time (must do it in the online event), or the unit has been set to a non-standard rate.
